Fundamental Frequency: Tension Force & Mass/Length
  • Thread starter Thread starter Soaring Crane
    String Vibrating
The discussion centers on determining the tension force in a string vibrating at its fundamental frequency. The correct answer to the question posed is option E, which lacks the mass of the string, a critical component for accurate tension force calculation. The formula v = sqrt(F_T/(m/L)) highlights the necessity of mass in determining tension. Option C, while including mass, also requires wave velocity and frequency for a complete calculation, making it sufficient.
  • Understanding of fundamental frequency in wave mechanics
  • Familiarity with the formula v = sqrt(F_T/(m/L))
  • Knowledge of linear density and its role in tension calculations
  • Basic concepts of wave velocity and frequency
  • Study the relationship between wave velocity and tension in strings
  • Explore the concept of linear density in string theory
  • Learn how to derive tension force from mass, wave velocity, and frequency
  • Investigate the implications of fundamental frequency in musical acoustics
Physics students, educators, and anyone interested in wave mechanics and the principles of tension in vibrating strings.
Soaring Crane
Which of the following values would NOT be sufficient to determine the tension force in a string vibrating at its fundamental frequency?
a. wavelength, mass, and freq.
b. wave velocity, mass, and wave length
c. masss, wave velocity, and string length
d. string length, freq., mass
e. string length, wave velocity, and freq.
E is the correct answer but C is wrong. Why is E the correct answer and not C?
I'm looking at the formula v = sqrt(F_T/(m/L))
Thanks.
On C look at the equation, you have everything except Tension, you can find it, On E you need mass, because you need linear density.
E is the correct answer because it does not include the mass of the string in the given values. In the formula, the mass of the string is represented as "m" and it is needed to calculate the tension force. Without the mass, it is not possible to determine the tension force accurately.
In option C, the mass of the string is included, so it would be sufficient to determine the tension force. However, it is not the only factor needed. The wave velocity and frequency are also needed to accurately calculate the tension force.
In option E, the mass is not included, which means that the given values are not sufficient to determine the tension force. The wave velocity and frequency are also not enough on their own. All three values - mass, wave velocity, and frequency - are needed to accurately calculate the tension force.
Therefore, option E is the correct answer as it does not include the mass of the string, which is a crucial factor in determining the tension force.
  • · Replies 29 ·
  • · Replies 23 ·
