Magnetic field of permanent magnet
The discussion revolves around estimating the magnetic field strength of a permanent magnet based on the weight it can lift. Participants explore various methods and considerations related to this estimation, touching on concepts from electromagnetism, force calculations, and practical applications.
  • Experimental/applied
  • inkpot suggests estimating magnetic field strength from the heaviest weight a magnet can lift through trial and error.
  • Another participant notes that the acceleration due to gravity must be considered, and proposes using Newton's second law to estimate the force applied by the magnet.
  • math_way argues that a formula for magnetic field strength requires an electric charge, implying that accurately determining the field strength based solely on lifting capacity is not feasible.
  • inkpot questions the necessity of an electric charge in the context of permanent magnets and seeks sources on the fundamental nature of magnetism.
  • Luca proposes using two repelling permanent magnets to measure force indirectly, but acknowledges the complexity due to varying strengths and distances.
  • One participant suggests treating the magnet as a pair of magnetic monopoles to estimate the induced magnetic field in the material being lifted, noting the influence of material susceptibility.
  • Another method mentioned involves moving a search coil through the magnetic field to measure induced emf, highlighting limitations of weight-based measurements.
  • inkpot shares that the inquiry is part of a broader investigation into using magnetism for damping motion in water, noting challenges due to the rapid decline of magnetic force with distance.
  • A later reply emphasizes that magnetic fields alone do not provide damping unless eddy currents are involved, suggesting alternative methods for damping oscillations.
Participants express a range of views on the feasibility of estimating magnetic field strength from lifting capacity, with no consensus reached. Some methods are proposed, but challenges and limitations are acknowledged, indicating ongoing debate.
Participants highlight various assumptions, such as the influence of distance on magnetic force and the need for specific conditions (like the presence of electric charge) to apply certain formulas. The discussion remains open-ended with unresolved mathematical and conceptual aspects.
inkpot
Is it possible to estimate the magnetic field strength of a permanent magnet from the heaviest weight that the magnet can lift? The heaviest weight that can be lifted can be found by trial and error.
Any comments or suggestions appreciated.
inkpot
I don't know much about electromagnetism, so I'm not sure if there is another equation unknown to me that makes this easier, but you the acceleration due to gravity is appox. 9.8 m/s^2 at ground level. For an object to be lifted straight up by a magnet the acceleration due to the magnet has to be > than 9.8 m/s^2.
Using Newton's second law of motion and the known masses of objects, you can guess at the force that is being applied, though if you had a laser accelerometer (which aren't cheap, but many high schools might have them) you could know far more accurately.
Hi inkpot,
As far as i know, there is'nt any formula you can apply to find magnetic field, unless there is an electric charge.
If there is an electric charge, then
Field strength = Magnetic Force/(charge * velocity)
Hence I am assuming, its not possible to accurately determine the Magnetic field strength, of a magnet, based on the heaviest load it can carry, as there are other factors that affect magnetic field, and only by using this formula will you be able to determine the field strength.
regards,
math_way
As the magnet in question is a permanent one why is it necessary for an electric charge to be present in the equation relating field strength and force?
Is there a good source on the fundamental nature of magnetism that anybody could suggest?
There is a very interesting discussion at https://www.physicsforums.com/showthread.php?t=3467
inkpot
Hi.
An idea could be to use TWO permanent magnets aligned so that one repel the other.
When second magnet is "floating" over the first one with no motion the force on the first magnet is the wheight of the second !
This gives NOT info on the force of the magnet: we have to read also the distance at which the equilibrium is obtaied: the distance will be higher for a stronger magnet...
Unfortunately this distance depends also on the strenght of the second magnet.
If someone make experiments and find a formula... i will be hasppy to use it !
I have build a nice non-contact scale using two repelling magnets with a load cell below the first :-)
Luca
It depends on what you are lifting. You might be able to get a rough estimate by treating the bar magnet as a pair of magnetic monopoles. The magnet will induce a magnetic field in the material you are lifting, depending on the magnetic susceptibility of the material. A table for many material is found at http://www.kayelaby.npl.co.uk/general_physics/2_6/2_6_6.html
I think it's possible, but it gets a little messy so it's not typically covered in the classroom.
One method could be to move a search coil or wire through the field at a known speed and find the induced emf in the wire.
Another would be to use a Hall Effect transducer.
Methods that involve picking up heavy weights are not very satisfactory because they are only measuring the field when the magnetic circuit is completed (the equivalent of a short circuit for susceptance when the weight is actually in contact) and does not tell you the field in the absence of the 'iron' weight. It would be affected greatly by the 'fit' of the test weight to the magnet.
Thank you all for your responses.
My reason for making the enquiry was part of an attempt to use magnetism, either with permanent magnets or electromagnetism, as a means of damping the motion of an object floating in water.
However, subsequent investigations seem to show that this may not be a practical option, mainly due to the way that the magnetic force declines very quickly with increased distance from the magnet. A supplier of rare Earth magnetics has a very good calculator on this subject, see http://www.kjmagnetics.com/calculator.asp .
A similar site can be found at http://magda.ucc.ie/
Best regards.
Thank you inkspot !
I have found the site http://magda.ucc.ie/ really useful...
Now I am looking for formulas used in this site to generate the graph :-)
Luca
I am glad that you found the magda site of use.
inkpot
Force to an iron between 2 magnets
Two magnets (A and B)has the same pulling energy, say 50 lbs. Put face by face on the same north poles (in repelling mode) in 10 mm distance. If a 3 mm bar iron strip/steel trip put in the middle of these 2 magnets, What will the forcstrip irone exerted on the strip iron/steel ? Howdo you calculate ?
Best regards.
A magnetic field will not provide any damping unless you use eddy currents, induced in a metal plate / disc. On its own, it will just produce an offset force without taking any energy out.
If you want to damp oscillations of a floating object then the thing to do is to use water damping with discs, drogues, seives or paddles under the water.
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 42 ·
  • · Replies 22 ·
