New Reply
Microswitch Voltage Usage Question
Share Thread Thread Tools
Mar10-12, 03:51 AM   #1
I've been thinking of using a microswitch in a project of mine. The switch should indicate when something is hit. However the thing is the voltage requirements I've seen for most of them are really high compared to the rest of what I'm using, as in I'm getting requirements of of over 100 volts of either direct or alternating current while the sensors and motors (which seem much more complicated and voltage consuming to me) require far less
I also remember reading somewhere that the voltage listed on the switches was mainly an upper limit and lower voltages could work. Is this correct? If not, what are are good suggestions for cheap low voltage and current alternatives?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Mar10-12, 03:54 AM   #2
Recognitions:
Homework Helper Homework Help
Hi A_someone!
The voltage rating on a switch is just its maximum; you can use any mechanical switch on tiny voltages. So go ahead and use it.
Mar10-12, 03:58 AM   #3
Recognitions:
Gold Membership Gold Member
hi welcome to PF
as long as the voltage and current ratings of the switch are higher than what you intend to put through the switch, then you wont damage the switch
is say you circuit is 12V, it doesnt matter if the switch is rated at 50V 100V or 200V
NOTE... MOST switches have both a DC and an AC voltage and current rating
Dave
Mar10-12, 10:18 AM   #4
Oh wow, thanks a lot to both of you for being friendly and responding so quickly!
The voltage and current ratings being the maximum does make a bit more sense to me; this will be really useful.
New Reply
Thread Tools
Similar Threads for: Microswitch Voltage Usage Question
Thread Forum Replies
Ti 83 Calculator usage question Calculus & Beyond Homework 2
Question of Memory and Brain usage. Medical Sciences 14
Basic question about quantum: Number operator usage Advanced Physics Homework 9
Quick Question on Maple Usage Math & Science Software 4
voltage and the usage of the word Introductory Physics Homework 2
