New Reply
Why does voltage drop to zero over a resistor?
Share Thread Thread Tools
Mar10-12, 12:48 PM   #1
How I am currently imagining it: In a simple circuit with just a battery and resistor the voltage of the battery sets the electrons off through the circuit at some speed and that speed is proportional to the voltage. The electrons then encounter the resistor.
From these forums my understanding of resistors is that the atoms in the resistor attract the electrons and work is required to push them past the resistors atoms. The electrons kinetic energy is transformed into light and heat energy, slowing the electrons down.
So why would the voltage drop totally across a resistor. If the resistance was small, wouldn't the electrons only need to expend a little bit of work and hence be slowed down just a little. If they are only slowed down a little wouldn't that mean there is still electrical pressure and hence voltage after the resistor?
I know that what I'm saying is not possible due to Ohms law, but I'd like to intuitively know what is going on.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Mar10-12, 01:24 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi robjow! welcome to pf!
Quote by robjow View Post
… the voltage of the battery sets the electrons off through the circuit at some speed and that speed is proportional to the voltage. The electrons then encounter the resistor… slowing the electrons down.
no
the number of electrons going past any particular point each second is the same all the way round the circuit
current means charge per time (past any particular point)
that's (obviously) proportional to electrons per time (passing any particular point)
it's like water flowing along a mill-stream …
when the water-wheel isn't obstructing the water, the water-speed is quite fast
when the water-wheel does obstructing the water, the water-speed is much slower, because the wheel is taking energy from the water,
and the speed of the whole stream is slower: the water doesn't suddenly slow down when it hits the wheel!
Mar10-12, 01:26 PM   #3
Recognitions:
Voltage is elecrical potential (link to wiki article below). The voltage in any circuit drops to zero by the time it reaches the negative terminal of a batter. Even in the case of a wire with no resistor, the wire is then the resistance, although it's very low, resulting in high current and a lot of heat dissipated. With a resistor, almost all of the resistnace is in the resistor, although there is still some resistance in the wires, so voltage isn't quite dropped to zero by the resistor except in an idealized model or a supercondutor. Since the resistor increases the overall resistance compared to just a wire, the current flow is much less and the amount of heat dissipated is also less (less power consumed), and almost all the heat dissipation occurs at the resistor.
http://en.wikipedia.org/wiki/Voltage
New Reply
Thread Tools
Similar Threads for: Why does voltage drop to zero over a resistor?
Thread Forum Replies
Resistor Voltage Drop Concept Question Electrical Engineering 15
Voltage drop across a resistor in a circuit Introductory Physics Homework 4
How is a voltage drop across a resistor caused? Classical Physics 2
Voltage drop and current for each resistor Introductory Physics Homework 8
Resistor currect and voltage drop in a circuit. Introductory Physics Homework 4
