Me In What My Teacher Said Is Easy
  • Thread starter Thread starter Chikawakajones
    Teacher
The discussion revolves around finding the value of x in a geometric context involving angles in a triangle and supplementary angles. Participants reference the properties of angles and theorems related to triangle geometry.
  • Participants discuss the relationship between angles in a triangle and supplementary angles. There are inquiries about the existence of specific formulas to find x, with some suggesting that the solution relies more on geometric reasoning than on formulas.
The conversation is ongoing, with participants sharing insights about angle relationships and theorems. Some guidance has been provided regarding the steps to approach the problem, but there is no explicit consensus on a single method or formula to solve for x.
Participants note that the problem requires understanding of geometric principles rather than relying on formulas, and there is a focus on the relationships between the angles involved.
Chikawakajones
Find the value of x. Show all work with justifications.
The sum of the three angles in a triangle is 180 degrees. The sum of two angles making a line is also 180 degrees: that leads to the well known theorem (it's probably in your text) that the measure of an external angle (here the one marked "125") is equal to the sum of the measures of the two opposite angles. One of those two opposite angles is 50 degrees. From that you can find the measure of the angle between "80" and "x" and then find x.
Are there any "formulas" to find "x" in this particular problem?...
Not that I know of
Beside this one
[tex]A+B+C=180°[/tex]
,where A,B,C are the three angles of a plane triangle,nope.
But,as Ivy said,u need to know that the sum of two supplementary angles is 180°.
This is all u need to know to get it done.
Daniel.
Again there are no formulas to solve this problem, it is all geometrical.
Step one.
Look at the angle 125. 180-125 will give you the angle on the other side of the line.
Step two add 55+50 and minus the product from 180. this is the upper angle.
Step three add 80+75 then minus that from 180 and that is the angle x
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 17 ·
