| New Reply |
Motion in Gravitational Field |
Share Thread | Thread Tools |
| Mar11-12, 09:56 PM | #1 |
I want to find out the general equations of motion for a particle with an initial velocity [itex]v_0[/itex] in a gravitational field by a point/spherical mass (assuming this is a large mass which doesnt move). Assume that the origin of the coordinate system is the point mass. If the vector equation of the particle's path is [itex]\mathbf{r}(t)[/itex], then the acceleration should be the second derivative,
[tex]\frac{d^2 \mathbf{r}}{dt^2}[/tex] The acceleration is caused by the gravitaional field (acceleration field) given by, [tex]A(\mathbf{r}) = GM\frac{\mathbf{r}}{|\mathbf{r}|^3}[/tex] But we already have the acceleration of the particle, [tex]\frac{d^2 \mathbf{r}}{dt^2} = GM\frac{\mathbf{r}}{|\mathbf{r}|^3}[/tex] So the general solution for [itex]\mathbf{r}[/itex] can be found by solving the above differential equation but I couldn't do it. Can anyone show me how it is done? |
| Mar13-12, 08:49 AM | #2 |
Does anybody know how to solve it or is there no exact analytic solution?
| Mar13-12, 01:19 PM | #3 |
Yes, this equation is solvable analytically. It is best to approach it using Lagrangians. The solutions are elliptical orbits first described by Kepler's laws.
| Mar13-12, 04:28 PM | #4 |
I have seen Lagrangians and Euler-Lagrange equation but I don't know them well. Would someone kindly show me the steps in the solution?
| Mar15-12, 10:25 PM | #5 |
Does any one know how to do it?
| Mar16-12, 03:18 AM | #6 |
By Kepler:
[itex]\frac{d^{2}r}{dt^{2}} = GM\frac{r}{|r|^{2}}[/itex]by Newton: F=ma, P=mv [itex]F=m*GM\frac{r}{|r|^{2}}[/itex]Where m is the mass of the orbiting body and M is the point mass (center of orbit). We also know that motion for a particle follows the path dictated by: [itex] r=r(r,θ,t)=re_{r}[/itex] [itex] v=e_{r}\frac{dr}{dt}+rωe_{θ}[/itex] [itex] a=e_{r}(\frac{d^{2}r}{dt^{2}}-rω^{2})+(rα+2ω\frac{dr}{dt})e_{θ}[/itex]This is using a polar coordinate system. If you substitute your acceleration into this equation and then solve for zero velocity, you will have a suitable equation for two dimensional orbit. For higher dimensions there is considerably more work, and I frankly have too much else to do! By the way: This is taken directly from Newton's equations of motion, Under General Planar Motion. |
| Mar16-12, 10:46 AM | #7 |
You can find a detailed derivation in Landau and Lifshitz, Mechanics.
| New Reply |
| Tags |
| differential, field, gravity, motion, vector field |
| Thread Tools | |
Similar Threads for: Motion in Gravitational Field
| Motion of light in a gravitational field | Special & General Relativity | 6 | ||
| Lagrangian Equation of motion for rod on pivot in gravitational field | Advanced Physics Homework | 10 | ||
| Circular Motion in SR/weak gravitational field limit | Special & General Relativity | 5 | ||
| droplet's motion in electric field and gravitational field? | General Physics | 2 | ||
| Equation of motion of particle in gravitational field | Introductory Physics Homework | 2 | ||
