Coulomb law for moving charges
The discussion revolves around the application of Coulomb's law to calculate the drift of charged particles in motion relative to each other. Participants explore the implications of changing distances on the forces and accelerations involved, as well as the mathematical modeling of these dynamics through differential equations.
  • One participant seeks to calculate the drift of charged particles using Coulomb's law but notes that as the distance increases, the force decreases, complicating the calculation of drift.
  • Another participant suggests using a differential equation to model the motion, specifically proposing the equation d²r/dt² = kq²/mr².
  • A different participant points out that the initial approach using constant acceleration is incorrect due to the variable nature of the forces involved and mentions the influence of magnetic fields created by the moving charges.
  • Further contributions involve deriving second-order differential equations and discussing the integration process to find velocity and position over time.
  • Participants express uncertainty about the initial conditions and the correct formulation of the differential equations, with some suggesting alternative methods or corrections to earlier claims.
  • One participant notes the complexity of the resulting integrals and the challenges in rearranging them to find specific solutions for r(t).
Participants do not reach a consensus on the correct approach to modeling the drift of moving charged particles. Multiple competing views and methods are presented, with ongoing debate about the appropriate mathematical treatment and the effects of varying forces.
Limitations include unresolved assumptions about the initial conditions, the dependence on definitions of distance and force, and the complexity of the resulting mathematical expressions. The discussion also highlights the challenges in integrating the derived equations.
This discussion may be of interest to those studying electromagnetism, differential equations, or anyone looking to understand the dynamics of charged particles in motion.
jo2jo
I am trying to workout the drift of a charged particle from another particle using coulomb law. but the problem is the further the particles move, the less the force between them, so how can I work out the drift in such case?
We know that the force between two charged particles is:
F = (k Q1 Q2)/r^2
where k is coulomb constant and r is the distance between the particles.
I can find the drift using Newton motion laws, by working out the acceleration (a) from the force (F = ma) m is the mass, and then using drift = (a.t^2)/2 + V0.t + x0 (assume v0 = 0 and x0 = 0).
You see the problem, the further the particles get the smaller the acceleration, and the smaller the drift, so how to treat this properly please?
welcome to pf!
hi jo2jo! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
You need a differential equation …
d2r/dt2 = kq2/mr2 :smile:
Your use of
[tex]x(t) = \frac{1}{2}at^2 + v_0t+x_0[/tex]
is incorrect. The above is only correct for situations of constant acceleration, which as you have pointed out, is not the case between particles. In addition, the moving charges will create magnetic fields that will affect the other particle which you are not accounting for. Regardless, one could get a rough first order approximation just using Coulomb's law. So the mechanics we have are:
[tex]\mathbf{a}_1 = \frac{kq_1q_2}{m_1x^2} \hat{x}[/tex]
[tex]\mathbf{a}_2 = -\frac{kq_1q_2}{m_2x^2} \hat{x}[/tex]
Take the integral of the acceleration to find velocity,
[tex]\mathbf{v} = \int_0^t \mathbf{a} dt + v_0[/tex]
And again to find position,
[tex]mathbf{x} = \int_0^t \mathbf{v} dt + 0[/tex]
I guess the only real trick is that both particles are in motion but you could deal with that by looking at the rest frame of one of the particles (which we really shouldn't do since it's an accelerating frame but for low velocities we can ignore relativity, especially since we are ignoring the magnetic fields). So in that case, I guess you could take the acceleration to be [itex]a_1+a_2[/tex] and since the particles will move symmetrically then we can simply correct for the calculated position by shifting the solved position appropriately.[/itex]
Gosh, I went to do the second order differential equation, do you agree with this?:
d2r/dt2 = kq2/mr2
Second order DE:
r(t) = A e√(m/kq^2)t + B e-√(m/kq^2)t
Notice (t) is outside the squared root, i just could not do it in the notation here.
I feel I missed it up! especially the initial conditions to get A and B :( . Any thoughts?
hi jo2jo! :smile:
jo2jo said:
d2r/dt2 = kq2/mr2
Second order DE:
no, that's the solution to d2r/dt2 = kq2r2/m :redface:
Thanks everyone,
To be honest I thought calculating the drift of two moving charged particles is something that has been done already. I could not find any online source to discuss this yet!
@tiny-tim, how comes (quoting: that's the solution to d2r/dt2 = kq2r2/m)?
I mean the acceleration that happens on one of the particles is:
d2x/dt2 , where x is the distance the particle moves.
From Coulomb's law, this acceleration is:
a = kq2/m(r+x)2
where r is the initial separation between the particles, so when the particle start moving x would increase and the force/acceleration would decrease. I guess that is sensible thought, do you agree? So it is second order differential equation:
d2x/dt2 = kq2/m(r+x)2
What do you think?
your solution is not the solution to your equation
jo2jo
The first thing to do with your DE is to multiply both sides by [itex]\frac{dr}{dt}[/itex].
Then integrate both sides wrt t.
This gives [itex]m\int^{v}_{dr/dt = 0} \frac{dr}{dt} \frac{d^{2}r}{dt^{2}} dt = kq^{2}\int^{r}_{r_{0}} \frac{1}{r^{2}}\frac{dr}{dt} dt[/itex].
So [itex]m\int^{v}_{dr/dt = 0} \frac{1}{2}\frac{d}{dt}(\frac{dr}{dt})^{2} dt = kq^{2}\int^{r}_{r_{0}} \frac{1}{r^{2}}dr[/itex].
So [itex]\frac{1}{2}mv^{2} = kq^2(\frac{1}{r_0} – \frac{1}{r})[/itex].
You'll recognise this as the energy equation, resulting from PE + KE = constant!
You've now only one integration to do. Go back to original notation, putting [itex]v = \frac{dr}{dt}[/itex], square root both sides of the equation, separate variables and – if you're a cheat like me – use the Wolfram online integrator.
@ Philip,, wow! If I progress from where you stopped:
sqrt(m/2kq2)v= sqrt(1/r0–1/r)
Lets just focus on v= sqrt(1/r0–1/r)
dr/dt = sqrt(1/r0–1/r)
(just to check, r0 is constant now, right?)
Integrating both sides with respect to (t) gives:
http://integrals.wolfram.com/index.jsp?expr=Sqrt[(1/x0)-(1/x)]&random=false
What do you think, did I mess it up?
By the way, for some reason, none of the online links that I used to re-study Second Srder DE mentioned the method you used, I was studying these ones http://www.intmath.com/differential-equations/1-solving-des.php and http://www.intmath.com/differential-equations/7-2nd-order-de-homogeneous.php!
r0 is indeed a constant: the starting separation.
What you haven't done is to separate variables. You'll see where this came from:
[itex]\frac{dr}{\sqrt{\frac{1}{r_{0}}-\frac{1}{r}}}[/itex] = [itex]\sqrt{\frac{2k q^{2}}{m}} dt[/itex]
You now integrate the lhs wrt r (Wolfram will help, if you obey the strict format rules), and the rhs wrt t (not too difficult!).
Good luck!
Many thanks Philip, I did actually the integration now, and that looks sooo messy, I mean because the result of the integration is very mixed up.
The rhs is just , right? [tex]\sqrt{\frac{2kq^2}{m}}t + c[/tex]
I rearranged the lhs to (I just used b instease of r0 less confusion):
[tex]\int{\frac{dr}{\sqrt{\frac{r-b}{rb}}}}[/tex]
[tex]\int{ \sqrt{\frac{rb}{r-b}}dr}[/tex]
.. and then integrated that wrt r, and got this mess!
[tex]\int{\sqrt{\frac{rb}{r-b}}dr} = \frac{\sqrt{\frac{br}{b-r}} (\sqrt{r} (r-b) +b\sqrt{r-b} \log (\sqrt{r-b} + \sqrt{r})) }{\sqrt{r}}[/tex]
(yes, cheated from wolframalpha)
So we have:
[tex]\frac{\sqrt{\frac{br}{b-r}} (\sqrt{r} (r-b) +b\sqrt{r-b} \log (\sqrt{r-b} + \sqrt{r})) }{\sqrt{r}} = \sqrt{\frac{2kq^2}{m}}t + c[/tex]
The problem here is, well!, how an Earth this can be rearranged so I can find the constant and then be able to find r(t) at certain times?
Sorry to bother you too much about this, I am still surprised I had to do all of that though this (two charged particles moving) seems to be a problem that someone else must have done before.
Well done jo2jo; it's a long time since I've done this, but I recall something like this mess emerging. I'll have a play with Wolfram in the next day or two; it can deliver its results in startlingly different forms, depending on the algebraic form in which you serve it the integrand.
I put it into Wolfram in the form 1/sqrt(1/b-1/x) and got a different mess, but one that seems to generate fewer problems – and no imaginary numbers as long as r>b. You can then find c by imposing the condition that r=b when t=0. I find [itex]c = b^{3/2} ln{b}[/itex].
Unfortunately I don't know how to copy Wolfram output to here, except by hand; is it easy to do?
Your final answer will be a complicated mess. Special cases will be simpler, for example if you decide that the interesting cases are when x>>b, then the mess will simplify a lot (though you mustn't throw away the baby with the bathwater).
Let me know how you get on?
Thanks Philip,
May I just go a step back and check the DE, really all the online sources I checked say follow certain format (blindly), but your method seems more generic with logical steps. I just need to clarify the step after multiplying both sides of the (=) by dr/dt, let's take first order DE:
[tex]\frac{dr}{dt} = \frac{kq^2}{mr^2}[/tex]
Multiply both sides by dr/dt
[tex](\frac{dr}{dt})^2 = \frac{kq^2}{mr^2} \frac{dr}{dt}[/tex]
[tex](\frac{dr}{dt})^2 dt = \frac{kq^2}{mr^2} dr[/tex]
Then integrate:
[tex]\int{ (\frac{dr}{dt})^2 dt} = \int{\frac{kq^2}{mr^2} dr}[/tex]
Now I got stuck in extracting what you did in the lhs, how did you get [itex]\frac{r^2}{2}[/itex] ? Any links you suggest me to study instead of keep bothering you on some sides things?
Your first equation isn't the right one. On the left we had the second derivative, not the first! I'm afraid you need to start again! Incidentally you might like to call kq^2 /m 'a' or something!
The method you're trying to reconstruct is a standard one for starting to deal with equations of the form [tex]\frac{d^{2}y}{dx^{2}} = f(y)[/tex].
If [itex]f(y) = ±k^{2}y[/itex] there are quicker methods, as given in the websites you referred to.
Thanks Philip,
The reason I went to First Order DE is I wanted to understand your way of solving DE rather than just get an answer, and that is why I asked for any online link to help in that.
The main part that I don't get in your Second Order answer is the lhs in:
[tex]\int{ \frac{dr}{dt} \frac{d^2r}{dt^2}}dt = kq^2 \int{ \frac{1}{r^2} \frac{dr}{dt}dt}[/tex]
I don't get the left hand side, how did it become
[tex]\int{ \frac {1}{2}\frac{d}{dt} (\frac{dr}{dt})^2}dt[/tex]
I don't know if there is a typo there that is confusing me or there is something am missing.
We're using the chain rule.
You'll agree that [itex]\frac{d}{dt}y^2 = 2y\frac{dy}{dt}[/itex] ?
In the case we're dealing with, [itex]y = \frac{dr}{dt}[/itex].
So [itex]\frac{d}{dt}(\frac{dr}{dt})^2 = 2\frac{dr}{dt}\frac{d^2r}{dt^2}[/itex].
It's no use, incidentally, practising the trick of multiplying by dr/dt if you have the first derivative on the lhs of the equation: it doesn't help! It's specific to the form of DE that I gave in my last post.
jo2jo. Let me know if that wasn't clear enough.
  • · Replies 17 ·
  • · Replies 44 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 42 ·
