Help with a large induction coil secondary
  • Thread starter Thread starter Lynton
    Coil Induction
The discussion centers on building an induction coil based on A. T. Hare's specifications, specifically addressing the confusion surrounding the dimensions of the coil's core and the importance of using thicker and thinner "pies" (likely referring to wire turns) for optimal performance. The dimensions mentioned include 96 pies of 3/16" each and a core length of 18", with a recommended spacing of 13" between coil ends. The user seeks clarification on how critical the variation in thickness is to the coil's efficiency and performance.
  • Understanding of induction coil design principles
  • Familiarity with A. T. Hare's methodologies
  • Knowledge of magnetic field dynamics
  • Basic electrical engineering concepts
  • Research the impact of wire gauge on induction coil performance
  • Explore A. T. Hare's induction coil construction techniques
  • Study the relationship between coil dimensions and magnetic field strength
  • Investigate diagrams and schematics of induction coils for better clarity
Electronics enthusiasts, hobbyists building induction coils, and engineers interested in electromagnetic applications will benefit from this discussion.
Lynton
I am about to build an induction coil in the traditional manner, after "A. T. Hare".
The dimensions intimated in the book are confusing and imply there are 96 pies 3/16" each or
18" long - this is the length of the core, and the book indicates around 13" between ends of coils.
The book also indicates thicker pies at the centre and thinner at ends,( following lines of magnetic force).
However the dimensions given in the Appendix are considerably removed from that indicated in the text and the drawing given.
My main question is "how important is the thicker/thinner pies to performance ?"
Can anyone assist please
Lynton
Sorry, what does the term "pies" mean in this context? Is it turns/cm? Or some other measure?
Can you post a diagram or links to what you have been reading? Thanks.
  • · Replies 34 ·
