More Schwarz inequality proofery
  • Thread starter Thread starter swevener
    Inequality
The discussion revolves around proving the Schwarz inequality, starting from a specific equation involving sums of squares and products of variables. Participants are exploring the logical steps required to transition from one form of the inequality to another without assuming equality prematurely.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the validity of their logical steps in proving the inequality, questioning whether certain assumptions can be made and how to handle terms in the equations. There is an exploration of starting points for the proof and the implications of manipulating the terms involved.
The discussion is ongoing, with participants providing feedback on each other's reasoning. Some guidance has been offered regarding the approach to take, and there is a recognition of the need to clarify certain steps in the proof process. Multiple interpretations of the logical flow are being explored.
Participants are reminded not to assume equality in their proofs and are encouraged to justify their steps clearly. There is an emphasis on understanding the implications of manipulating terms in the context of inequalities.
swevener
Prove the Schwarz inequality by first proving that
[tex](x_{1}^{2} + x_{2}^{2})(y_{1}^{2} + y_{2}^{2}) = (x_{1} y_{1} + x_{2} y_{2})^{2} + (x_{1} y_{2} - x_{2} y_{1})^{2}.[/tex]
[tex]x_{1} y_{1} + x_{2} y_{2} \leq \sqrt{x_{1}^{2} + x_{2}^{2}} \sqrt{y_{1}^{2} + y_{2}^{2}}[/tex]
I'm not sure if my logic is right. I did the little proof above, and with that I can say
[tex]-(x_{1} y_{2} - x_{2} y_{1})^{2} \leq (x_{1} y_{1} + x_{2} y_{2})^{2}.[/tex]
Can I then sweep the LHS under the zero and say
[tex](x_{1} y_{1} + x_{2} y_{2})^{2} \leq (x_{1}^{2} + x_{2}^{2})(y_{1}^{2} + y_{2}^{2}),[/tex]
then take the square root to finish the proof?
You don't need your relevant equation!
You can prove the equality holds by simply starting with one side of the equation (remember not to assume they are equal, that would be assuming what you're trying to prove!) and end up with the other.
You can start with either side to get the other but I'd suggest starting with the right hand side.
See what you come up with!
I did that part. I'm asking if I got from there to the Schwarz inequality, the "relevant equation", logically.
Okay, sorry, I didn't see that line of text.
So what you're doing (I think you left this step out) is saying that [itex](x_{1} y_{1} + x_{2} y_{2})^{2} + (x_{1} y_{2} - x_{2} y_{1})^{2} \geq 0[/itex] because the values are both positive and then you subtracted the one term. I'm still not sure how you went from the third equation in your post to the final equation. I think you can word that a little bit better? I get the sense you have to the right idea and understand why it's true, it just isn't obvious to me from reading it why you did it.
Yeah, I started with
[tex]0 \leq (x_{1} y_{1} + x_{2} y_{2})^{2} + (x_{1} y_{2} - x_{2} y_{1})^{2},[/tex]
and since being squared mean both terms will always be positive, multiplying one of them by -1 makes that one always less than or equal to the other:
Although looking at it now, I think I threw that in there just so I didn't disappear the LHS without comment. What I had in mind was this sort of thing:
[tex]-(x_{1} y_{2} - x_{2} y_{1})^{2} \leq (x_{1} y_{1} + x_{2} y_{2})^{2} \leq (x_{1}^{2} + x_{2}^{2})(y_{1}^{2} + y_{2}^{2})[/tex]
And then just cut out the [itex]-(x_{1} y_{2} - x_{2} y_{1})^{2}[/itex], because I'm not sure how else to get rid of it.
Okay, I get what you are saying now. I think this way might be a little easier, you can be the judge.
If [itex]a^{2} = b^{2} + c^{2}[/itex], then [itex]a^{2} \geq b^{2}[/itex]. I don't see any reason to "justify" getting rid of the [itex]c^{2}[/itex] term, it's just extra that you don't need.
So, this is basically what you are doing except not trying to fiddle with the [itex]c^{2}[/itex] term. All you have to do is explain why an inequality appears when you get rid of the [itex]c^{2}[/itex] term.
Okay, thanks.
  • · Replies 19 ·
