HELP Find the mass in this inclined pulley system, required to move the 2 masses
The problem involves an inclined pulley system with two masses, one on an incline and one hanging vertically. The scenario includes parameters such as mass values, angles, and coefficients of friction, with specific questions regarding motion and required mass to initiate movement.
  • Participants discuss the conditions under which the masses will move, questioning the assumptions about acceleration and the calculations for static friction. There is an exploration of how to determine the mass needed to initiate movement.
The discussion is ongoing, with participants offering various approaches to calculate the required mass and questioning the assumptions made in the problem. Some guidance has been provided regarding the calculation of static friction and the forces acting on the masses.
Participants note the lack of explicit information regarding acceleration in the problem statement, leading to questions about whether it can be assumed to be equal to one. There is also mention of the need to consider the forces acting on both masses in the equations.
dani123
In this problem they show a diagram of a pulley system with an inclined plane (25 degree incline). There is a box called m1=47kg resting on the incline plane and m1=35kg hanging on the vertical line. The question reads: The coefficient of friction between m1 and the surfvace of the inclined plane are Ustatic=0.42 and Ukinetic=0.19.
a)if the masses are held in place and then released , will they start to move? ------> I know the answer is NO.
b)how much mass would you have to add to m2 to cause the masses to begin to move? ----> The answer should be 2.8kg but I don't know how the book got this answer.
c)If you said no to a) and added the mass that you calculated in b), what would be the acceleration of the masses? ---> answer given in the back of textbook is 5.7 m/s^2
ANY help with this problem would be greatly appreciated! THANK YOU SO MUCH in advance :)
For m1=47kg
Fparallel=mgsin(25)=194.7N
Fg=47*9.8=461N
Fperpendicular=Fn=417N
Ffk=uk*Fn=0.19*417=79N
Applying Newton's 2nd law to m1
Fparallel-Ff-Ft=194.7-79-Ft=47*a
For m2=35kg
Fg=35*9.8=343N
Apply Newton's 2nd law to m2
Ft-343N=35*a
combine the two equations involving acceleration and cancelling out the force of tensions... this only leads us to an equation that ends up giving us a=-2.77m/s^2... but this is where I am stuck... how do I find the mass required to get both masses to move?!
can we assume the acceleration is equal to 1 when we are trying to determine the mass of m2, since they did not specify in the question?
Would it be safe to say that the acceleration is equal to 1 if they do not specify in the question?
You know that the force of static friction is Fs≤μmgcos(25). Calculate the static friction when a=0 and check if it is less than μmgcos(25). Then suppose that Fs =μmgcos(25) and find the mass to add to m2 so you get a=0.
ehild
Do I use the m2 for both of those equations?
The force of friction is calculated for m1=47 kg.
Do what you did in the first post: Collet the forces acting both m1 and m2, and cancel the tension.
ehild
  • · Replies 66 ·
