New Reply
centripetal force
Share Thread Thread Tools
Mar14-12, 05:34 PM   #1
centripetal force
Find the centripetal force required to rotate 6 kg object in a circle at a radius of 6m at one revolution per second.
2. Relevant equations
C.F. = mv2/r
[b]3. The attempt at a solution[/b
Circumference=2 pi r=2*3.14*6=37.68
C.F. = 6*(37.68)2/6=1419.78
I just want to check whether my working is correct or not.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar14-12, 06:15 PM   #2
that's about what I got too ^^
Mar14-12, 06:54 PM   #3
Looks like you wrote down
CF = m v2/r
but then you calculated the circumference, C = 2 π r
and then you said,
CF = r C2/6 = C2
Why would you expect the centripetal force to be equal to the square of the circumference?
It really is not.
Try it again, starting with CF = m r ω2 and see how that turns out for you. You failed to get the time information into the problem.
Mar15-12, 06:26 AM   #4
centripetal force
so
CF = m r ω2
CF = 6*6*(37.68)2=51112???
Mar15-12, 06:33 AM   #5
Quote by OldEngr63 View Post
CF = m v2/r
and then you said,
CF = r C2/6 = C2
It really is not.
That's not really what he is doing, I think... He is doing CF = m v^2 / r, it just so happens that v is one circumference per second and that m and r have the same numerical value...
Mar15-12, 07:52 AM   #6
now i am confused :C
Mar15-12, 08:19 AM   #7
Quote by John78 View Post
You shouldn't be, you got it right the first time around.
However, to get it right with the second formula, you have to use the proper value for ω, which in this case is 2π/s.
It would probably clear things up, if you would carry the units throughout your calculation and not just the numbers, that way you can always check if your result makes sense.
Mar15-12, 08:21 AM   #8
I think your working is correct
New Reply
Thread Tools
Similar Threads for: centripetal force
Thread Forum Replies
Physics Lab Centripetal Force - deriving the error in the calculated centripetal forc Introductory Physics Homework 3
Why does the centripetal force subtract from total force toward center? Introductory Physics Homework 12
Finding the Normal Force of a block on an incline experiencing centripetal force Introductory Physics Homework 1
Centripetal Force + Frictional Force + Braking Introductory Physics Homework 5
ranking net force/ centripetal force problem Introductory Physics Homework 1
