Centripetal force of an object swinging
The discussion revolves around calculating the centripetal force and velocity of an object being swung on a string, with varying weights from 200 grams to 1100 grams and a fixed string length of 0.5 meters. Participants are exploring the relationships between centripetal force, velocity, and the necessary graphs to represent these relationships.
  • Participants discuss using the equations for velocity and centripetal force, questioning whether to use the circumference divided by time or the centripetal force formula. There is also a focus on the expected shapes of the graphs relating force to velocity and velocity squared.
Some participants have provided guidance on how to derive velocity and the expected graph shapes, while others express confusion about the parabolic nature of the graphs and seek clarification on the relationships involved. Multiple interpretations of the graphing requirements are being explored.
Participants are working within the constraints of a homework assignment, which may limit the information available for discussion. There is an emphasis on ensuring the graphs meet specific criteria related to the relationships between force, velocity, and velocity squared.
JWest
I have to find the centripetal force and velocity of an object being swung around on a string that is attached to a weight (starting at 200 grams up to 1100 grams). The length of the string (radius) that is swinging the object is .5 meters. I have the times for each mass (200g-1100g). How would I approach this problem? To find the velocity, would I use the equation V=d/t, where "d" is the .5 meters and "t" is the time it takes for the object to be swung around once, or should I use the equation Fc=m(v^2/r), where "Fc" is the weight (Fg), mass is the weight, and radius is the string distance of .5 meters? Plus, I need to make 2 graphs the data where "Fc" is the y-axis and "v" is the x-axis and it has to be a parabola and "Fc" is the y-axis and "v^2" is the x-axis and it has to be a straight line like this - /. Can anyone help me?
You can figure out V from the circumference of the circle divided by the amount of time it took the object to go around once. From there it's pretty much straightforward.
The graph being a parabola also makes perfect sense since the F(v) of Fc is v^2/r where 1/r is a constant meaning the vertical stretch.
The graph is a line when F(v^2) of Fc since the slope will be 1/r and again is a constant, which implies that the graph is a line.
And v^2 is just the velocity squared? I didn't get the parabola for the Fc vs. V graph.
You should... the graph is suppose to be F(v) = v^2/.5 where F(v) = Fc
Say v = 1 then F(c) = 2
...2 ......8
...3......18
...-1......2
...-2.....8
...-3......18
If you continue in this fashion and plot the points, it will be a parabolic. Even graph this on a graphing calculator with x^2/.5...
