Maximum Compression of Spring in Spring Loaded Collision
  • Thread starter Thread starter moonbase
    Collision Spring
The problem involves a collision between two carts, one of which carries a spring. The objective is to determine the maximum compression of the spring during the collision. The relevant subject areas include mechanics, energy conservation, and spring dynamics.
  • Participants discuss the calculation of mechanical energy in the center of mass frame and its implications for the spring's potential energy. There are attempts to reconcile different energy values and the conditions for maximum compression of the spring.
The discussion is ongoing, with participants exploring various interpretations of energy conservation and the role of the center of mass frame. Some participants have provided calculations and questioned the correctness of their results, while others suggest alternative approaches to the problem.
There are indications of confusion regarding the energy values and the implications of the center of mass frame on the spring's compression. Some participants mention the lack of access to calculators, which may affect their calculations.
moonbase
A cart of mass m = 3 kg carrying a spring of spring constant k = 46 N/m and moving at speed v = 2.8 m/s hits a stationary cart of mass M = 8 kg. Assume all motion is along a line. What is the maximum amount the spring will be compressed?
PEspring=0.5kx2
KEinitial=0.5mv2
A previous part of this question asked me to calculate the mechanical energy in the center of mass frame, which I correctly found to be 8.55 J. I then had to find the total potential energy of the system when the spring is fully compressed, which I correctly calculated to also be 8.55 J. But when I plug this into the spring energy equation, the value I get for x is apparently incorrect.
0.5(46)x2=8.55 -> x=0.61
I must be missing a step here. Anyone see what I did wrong?
PEspring=0.5kx2
KEinitial=0.5mv2
How incorrect was your answer?
By my calculation, there was only about 7.15 J of energy stored in the spring? I may have been wrong - I did not have access to a calculator and couldn't be bothered using excel.
The program doesn't tell me how far off I am, but it told me that 8.55 in indeed correct for the spring's energy. Though when I inquire about it, it says "Look at this in the center of mass frame and consider how there is 8.55 J of mechanical energy. What does this say about the velocity of the carts in the center of mass frame when the spring is fully compressed?"
I can't seem to find the problem, I tested it and know it's not a sig fig issue.
If you ignore the reference to the centre of mass frame, and proceed in the usual way, you can calculate the energy before - only the 3 is moving - then use concervation of momentum to find the common velocity that occurs when the spring is at maximum compression. From that find the Kinetic energy at the time. You then know how much energy is stored in the spring.
I didn't get 8.55 [as I said without a calculator so I may have slipped].
If the answer is different, and leads to the correct compression there is an interesting puzzle to ponder.
Yea I tried that too, the kinetic energy being 11.76 J and the compression being 0.715 m, but that didn't work either. It also didn't accept it when I tried it with what you calculated (0.558 m) so I'm really not sure what's wrong here. If it helps, here's how I got 8.55:
vcm=[3(2.8)+8(0)]/(3+8)=0.7636 m/s
v1,cm=2.8-0.7636=2.036 m/s
v2,cm=0-0.7636=-0.7636 m/s
KEtotal=0.5(3)(2.0362)+0.5(8)(-0.76362)=8.55
Nevermind, I realized that the answer is zero. The compression in the center of mass frame is like momentum, the total is zero because the values of both sides cancel out. Thanks for your help though!
  • · Replies 17 ·
