| New Reply |
Finding the minimum of an unknown function by the least amount of tries |
Share Thread | Thread Tools |
| Mar16-12, 04:07 AM | #1 |
I am working on a program that queries an electronic instrument in order to find a value x for which the instrument will return a minimum value. I can provide any value for x that I want and the instrument will return the result f(x). The function has only one minimum. In order to test my algorithm, I created a function and I would like to know how can find the minimum of this function using as few tries as possible. Once I am pretty happy with the algorithm, I will implement it in the real program. I thought of a simple algorithm (which I admit is pretty dumb and it may not converge for a slightly different function or for any start value of x). With my algorithm, if I start with x = 0, it will take me 35 tries to identify x for which f(x) is minimum (when x = -4.8671, f(x) = 0.9426). 2. Relevant equations f(x) = 0.5*(0.29*x*(x+2)+0.22*x+3-3*sqrt(x*x-3*x+9)+12.88-x/1.33); 3. The attempt at a solution a. choose a random start value b. choose a random step c. query the function what is the result yleft = f(xstart - step) d. query the function what is the result yright = f(xstart + step) e. query the function what is the result of y = f(xstart) f. if yleft < yright, then x must be somwhere to the left, so xleft = x-2*step, xright = x g. if yright < yleft, xleft = x, xright = x+2*step h. More details in the sample program provided below. x = 0; xStep = 2.0; y = Function(x); xl = x - xStep; xr = x + xStep; do { n++; yl = Function(xl); yr = Function(xr); x = (xl + xr) / 2; y = Function(x); if(yl <= yr && yl <= y) { Dir = Left; //minimum is probably to the left of X, but not necessarily! x = (xl + xr) / 2; xr = x; xl = xl - 2 * xStep; } else if(yr <= yl && yr <= y) { Dir = Right; //minimum is probably to the right of X, but not necessarily! x = (xl + xr) / 2; xl = x; xr = xr + 2 * xStep; } else if(y <= yl && y <= yr) { Dir = Center; xStep = xStep * 0.70; // I found by trial and error that 0.70 is a value that converges decently fast xl = xl + xStep; xr = xr - xStep; } } while(fabs(yr - yl) > 0.0001 && n < 100); Certainly there are much better algorithms than this one, so any suggestions are welcome. Kind regards, Nicolae |
| Mar16-12, 05:12 AM | #2 |
Recognitions:
Hi NickF!
![]() Does the function have only one dip and that's the minimum? |
| Mar16-12, 05:18 AM | #3 |
Recognitions:
Iff it has only one dip, wouldn't bisection be simplest? Get the y values for xmin, xmax, and the mid x value. Then move your attention to one of those halves, repeatedly.
The number of evaluations needed will depend on the accuracy you require. Just noticed your polynomial test function, so graphed it here http://fooplot.com/index.php?&type0=...min=0&ymax=100 It has only one dip, so if this is representative, maybe try bisection. |
| Mar16-12, 05:29 AM | #4 |
Finding the minimum of an unknown function by the least amount of triesI will try what you said and report the results. Thanks for help. Best regards, Nicolae |
| Mar16-12, 05:42 AM | #5 |
Regards, Nicolae |
| Mar16-12, 06:10 AM | #6 |
Recognitions:
Can you see any problems with this? |
| Mar16-12, 06:28 AM | #7 |
Nicolae |
| Mar16-12, 02:21 PM | #8 |
Recognitions:
http://www.math.ucf.edu/~xli/Fibonacci%20Search.pdf (Fibonacci) and http://en.wikipedia.org/wiki/Golden_section_search (Golden Section). RGV |
| Mar16-12, 08:47 PM | #9 |
I implemented the suggested algorithm and it works quite well. Probably it is enough for my needs. Thank you very much for help. I got some more replies, I might try a different method, just for fun. Best regards, Nicolae |
| Mar17-12, 01:36 AM | #10 |
Recognitions:
There is a vast literature devoted to univariate function minimization using only function values; there is no good reason to re-invent the wheel in practical problem-solving. RGV |
| Mar17-12, 01:43 AM | #11 |
The Fibonacci algorithm seems a very good choice, I will try to implement it as well. I am curious how many steps I can save between the algorithm suggested by NascentOxygen and Fibonacci's algorithm on my test function. I will post the comparison results. Best regards, Nicolae |
| Mar17-12, 03:42 AM | #12 |
Recognitions:
However, suppose you do not have a starting interval; then what? For the Golden section method there are starting routines that are quite efficient. If r = (sqrt(5)-1)/2 = 0.618034 is the Golden Section, then: start with x0 = 0 (for example), and let d be some step size. Set x1 = x0+d, x2 = x0 + (1+r)*d, x3 = x0 + (1+r)^2*d, etc. Stop as soon as you find f(x_i) < f(x_{i+1}) : take a = x_{i_1} and b = x_{i+1} as the initial uncertainty interval. (In the special case f(x0) < f(x1), take a=x0 and b = x1.) Note that if i > 1 you already have one correctly-placed point (x_i) in this interval, so you need only one more f(x) evaluation to reduce length of the interval [a,b] by factor r. Each additional f evaluation reduces the interval by factor r, so after n function evaluations in [a,b] the new uncertainty interval's length will be r^n*(b-a). For example, for n = 10 we have r^10 = 0.00813. RGV |
| Mar17-12, 03:55 AM | #13 |
If I understand correctly, the Golden Section method is possibly one step slower than Fibonacci Search method, but it has the advantage of not requiring a known starting interval that contains the minimum? If this is the case, I would prefer this method (especially if it is easier to implement - although I had a brief look to Fibonacci Search and it does not seem too difficult). Regards, Nicolae |
| Mar22-12, 06:33 AM | #14 |
Hi All,
I completed the Fibonacci Search program. Because I could not find a C/C++ sample program, I will add my work in here, maybe it will help somebody else. I used Borland C++ Builder, but it is simple enough to be ported to other platforms. Regards, Nicolae void __fastcall TForm1::btnFibonacciSearchClick(TObject *Sender) { FibonacciSearch(); } //--------------------------------------------------------------------------- double __fastcall TForm1::Function(double x) { double y; // y = 0.5*(0.29*x*(x+2)+0.22*x+3-3*sqrt(x*x-3*x+9)+12.88-x/1.33); // y = x*x*x*x*x -(4.0/5.0) * x + 0.5; y = x * x - sin(x); return y; } //--------------------------------------------------------------------------- void __fastcall TForm1::FibonacciSearch() { double y, x; double a, b, c, d; double eps = 1e-4; double e = 0.01; double Fn; double r; double ya, yb, yc, yd; int n, k; a = 0; b = 1; Fn = (b - a) / eps; n = ReverseFibonacci(Fn); for(k = 1; k <= n; k++) { r = (double) Fibonacci(n - k - 1) / (double) Fibonacci(n - k); c = a + (1 - r) * (b - a); d = a + r * (b - a); yc = Function(c); yd = Function(d); if(yc < yd) { //remove the point outside the higher of the two center points - d is higher, remove b -> d bcomes b b = d; yb = yd; d = c; yd = yc; c = a + (1.0 - (double) Fibonacci(n - 1 - k) / (double) Fibonacci(n - k)) * (b - a); yc = Function(c); } else if(yc > yd) { a = c; ya = yc; c = d; yc = yd; d = a + ((double) Fibonacci(n - 1 - k) / (double) Fibonacci(n - k)) * (b - a); yd = Function(d); } DispFibMsg(k, a, b, c, d, yc, yd); } } //--------------------------------------------------------------------------- void __fastcall TForm1::DispFibMsg(int k, double a, double b, double c, double d, double yc, double yd) { mHistory->Lines->Add("k = " + IntToStr(k)); mHistory->Lines->Add(""); mHistory->Lines->Add("a = " + FloatToStrF(a, ffFixed, 8, 6) + ";\t b = " + FloatToStrF(b, ffFixed, 8, 6)); mHistory->Lines->Add("c = " + FloatToStrF(c, ffFixed, 8, 6) + ";\t d = " + FloatToStrF(d, ffFixed, 8, 6)); mHistory->Lines->Add("yc = " + FloatToStrF(yc, ffFixed, 10, 9) + ";\t yd = " + FloatToStrF(yd, ffFixed, 10, 9)); mHistory->Lines->Add(""); Application->ProcessMessages(); } //--------------------------------------------------------------------------- long __fastcall TForm1::Fibonacci(int n) // n >= 3 { long fibn, fibpn, temp; //fibonacci[n] and fibonacci[n-1] int i; fibn = 2; fibpn = 1; for(i = 1; i < n - 2; i++) { temp = fibn; fibn = fibn + fibpn; fibpn = temp; } return fibn; } //--------------------------------------------------------------------------- int __fastcall TForm1::ReverseFibonacci(double Fn) { //returns which term of the Fibonacci series has a value greater than Fn long fibn, fibpn, temp; //fibonacci[n] and fibonacci[n-1] int i; fibn = 2; fibpn = 1; for(i = 1; i < 1000; i++) { temp = fibn; fibn = fibn + fibpn; fibpn = temp; if(fibn >= Fn) return i + 3; } return -1; } //--------------------------------------------------------------------------- |
| Mar22-12, 11:21 AM | #15 |
Recognitions:
RGV |
| New Reply |
| Tags |
| minimum function |
| Thread Tools | |
Similar Threads for: Finding the minimum of an unknown function by the least amount of tries
| how to find an unknown amount (titration) | Biology, Chemistry & Other Homework | 2 | ||
| Finding Unknown Function f(x) | Precalculus Mathematics Homework | 3 | ||
| Finding an Integral from an Unknown Function | Calculus & Beyond Homework | 1 | ||
| Finding the maximum and minimum points of a cosine function... | Calculus & Beyond Homework | 9 | ||
| Finding the integral of an unknown function | Calculus | 6 | ||
