New Reply
conservation momentum/energy
Share Thread Thread Tools
Mar16-12, 03:55 PM   #1
A bullet of mass 1.4×10−3 {\rm kg} embeds itself in a wooden block with mass 0.999 {\rm kg}, which then compresses a spring (k = 110 {\rm N/m}) by a distance 5.5×10−2 {\rm m} before coming to rest. The coefficient of kinetic friction between the block and table is 0.46.
a)what is the initial speed of the bullet?
b)What fraction of the bullet's initial kinetic energy is dissipated (in damage to the wooden block, rising temperature, etc.) in the collision between the bullet and the block? (answer: ΔK/K
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar16-12, 04:07 PM   #2
You must attempt to at a solution first before we can help you.
Mar16-12, 04:37 PM   #3
Quote by tal444 View Post
i did i didn't feel like typing it, but here ya go.
i started by drawing a diagram labeling part A to be where the spring is compressed, part B to be where the block started pushing the spring, part C to be where the bullet impacts the block, and part D the firing of the bullet.
I then used energy conservation, stating that the E@A=E@B. 1/2kx^2=1/2mv^2, solving for v and getting sq.rt of (kx^2/m). plugging in the numbers i get v=.5767 m/s. Then i attempt to use energy conservation from B to C, 1/2mv^2=1/2mv^2-(work by friction+work by spring) but i kind of just put that equation together myself because i know energy is lost by work done) and i dont really know what to do.
New Reply
Tags
energy, momentum, work
Thread Tools
Similar Threads for: conservation momentum/energy
Thread Forum Replies
conservation of momentum vs conservation of kinetic energy Introductory Physics Homework 18
WHat is more fundamental - conservation of momentum or conservation of energy? Classical Physics 12
linear momentum conservation vs mecanical energy conservation General Physics 1
Simulatenous Conservation of Momentum and Conservation of Energy Engineering Systems & Design 9
Conservation of momentum (with conservation of energy) Introductory Physics Homework 1
