| New Reply |
Calculate the energy density of the Earth's atmosphere |
Share Thread |
| Mar17-12, 09:44 AM | #1 |
Not really homework, just practice for a midterm, I also have the correct answers; but I guess this is the correct section.
1. The problem statement, all variables and given/known data In the Earth's atmosphere we have an electric field with a vertical direction down towards the earth. The lower part of the atmosphere has a typical field strength of 100 V/m. The strength of the earth's magnetic field is approximately 50*10^(-6) T. Find the energy density in each of the two layers. I assume the "two layers" are the upper and lower layers. 2. Relevant equations [tex] \mbox{Energy density} = \frac{\mbox{Electric energy}}{\mbox{Volume}} = (1/2)\kappa \epsilon_0 E^2[/tex], where k is the Dielectric constant, e_0 is the permittivity of the space (8.85*10^(-12)) We also have that [tex]\kappa = \frac{E_0}{E}, E = \frac{F}{q_0}[/tex]. 3. The attempt at a solution I assume that I could just obtain the energy density directly from using [tex](1/2)\kappa \epsilon_0 E^2[/tex] directly? I know the correct answers should be [tex]u_1 = 4.4\cdot 10^{-8} J, u_2 = 4.4\cdot 10^{-4} J[/tex] However I don't know how to proceed to obtain the variables. |
| Mar17-12, 01:41 PM | #2 |
hi phystudent515!
![]() i find the question very confusing ![]() also the answer … energy density isn't in J, it's in Pa (pascals) ![]() have you given us the whole question? |
| Mar17-12, 05:48 PM | #3 |
I did omit some text due to it being translated by hand. I'll try to restate the problem text somewhat better worded (due to translation): I have tried the following to obtain the same solutions: For the electric field: [tex](1/2)\kappa \epsilon_0 E^2[/tex] = 1/2 * 1 * 8.85*10^(-12) * 100^2 = 4.4 * 10^(-8), which is correct. For the magnetic field: I use [tex](1/2) \epsilon_0 E^2 + \frac{B^2}{2\mu_0}[/tex] = 1/2 * 8.85*10^(-12) * 100^2 + (50*10^(-6))^2/(2*4*pi*10^(-7)) = 9.94*10^(-4), which is not correct. I observe however that it is roughly twice that of the result I'm looking for. |
| Mar19-12, 05:22 AM | #4 |
hi phystudent515!
![]() yes, that second 4.4 is clearly a misprint … the typesetter has got bored and typed the number twice! ![]() 1/2 B2/µo is the correct formula btw, J/m3 and Pa are the same, see eg http://en.wikipedia.org/wiki/Energy_...Energy_density … |
| New Reply |
Similar discussions for: Calculate the energy density of the Earth's atmosphere
| Calculate pressure of Atmosphere | Introductory Physics Homework | 1 | ||
| Early Earth Atmosphere | Earth | 11 | ||
| Earth's atmosphere | Chemistry | 2 | ||
| Earth's Atmosphere | Earth | 8 | ||
| Earth without the atmosphere | General Discussion | 4 | ||
