Solving equation with numerical analysis
This discussion focuses on solving a transcendental equation from Propeller Blade Theory, specifically equation 2.3.25, using numerical analysis techniques. Participants emphasize that there is no closed-form analytic solution for this type of equation, similar to Kepler's equation. The recommended approach involves substituting numerical values for variables and utilizing numerical methods to solve for εi across a specified range of r values. A polynomial fit to the resulting graph of εi versus r is suggested for further mathematical analysis.
  • Understanding of transcendental equations
  • Familiarity with numerical analysis techniques
  • Basic knowledge of polynomial fitting
  • Experience with graphing data
  • Research numerical methods for solving transcendental equations
  • Learn about polynomial regression techniques
  • Explore the application of numerical analysis in engineering contexts
  • Study Kepler's equation and its numerical solutions
Engineers, mathematicians, and students involved in numerical analysis, particularly those working with equations in fluid dynamics and propulsion systems.
AeroTron
need hint/help or perhaps a solution :smile:
Equations are from Propeller Blade Theory. I´m trying to figure out how to determine
[itex]\epsilon[/itex]_i from equation 2.3.25
my first thought was to substitute sin(A+B) = sinA*cosB + cosA*sinB...
it says quote: " This equation is easily solved numerically" but I have no clue what to do or where to start.
Thanks
A numerical solution deals with numbers. In the absence of better advice, this is how I'd interpret it:
Substitute a numerical value for each variable in equation 2.3.25 until you have an equation comprising numbers, r, εi and nothing else. Then, for example,
for r=5 to 300 in steps of .1
solve for the corresponding εi (do this using a numerical technique)
To your graph of εi vs. r fit a simple polynomial to allow easy mathematical analysis for the region of practical interest.
Does that sound right?
Thanks
You are trying to solve the equation analytically. There is no closed form analytic solution to that equation, at least not in the elementary functions.
There are plenty of relations that can be expressed very simply one way but not the reverse. A very simple example is Kepler's equation, [itex]M = E - e\sin E[/itex]. There is no simple way to express [itex]E[/itex] in terms of [itex]e[/itex] and [itex]M[/itex]. One instead solves the reverse Kepler problem using numerical methods.
The same applies to your problem. Your problem is a transcendental equation, and transcendental equations in general do not have closed form solutions. So you use numerical techniques instead. This page, http://en.wikibooks.org/wiki/Numerical_Methods/Equation_Solving gives a brief overview of some of the numerical techniques that can be used to solve such equations.
  • · Replies 16 ·
