Actually calculating the Lebesgue Outer Measure of a set
  • Thread starter Thread starter jdinatale
    Measure Set
The discussion focuses on calculating the Lebesgue Outer Measure of a set using the symmetric difference notation S(A, B) and the outer measure D(A, B). The outer measure is defined in terms of countable coverings of sets with intervals in R^2, specifically using rectangles instead of intervals. The calculation presented concludes that D(A, B) equals 36 by summing the outer measures of the respective rectangles. For further clarification, the outer Lebesgue measure on R^2 is established through countable coverings by rectangles.
  • Understanding of Lebesgue measure theory
  • Familiarity with symmetric difference notation S(A, B)
  • Knowledge of outer measure definitions in R^2
  • Basic concepts of covering sets with intervals or rectangles
  • Study the construction of the Lebesgue measure on R^2
  • Learn about countable coverings and their applications in measure theory
  • Explore the properties of symmetric differences in set theory
  • Review examples of calculating outer measures using rectangles
Mathematicians, students of measure theory, and anyone interested in advanced calculus or real analysis will benefit from this discussion.
jdinatale
If you are unfamiliar with that notation, S(A, B) = (A \ B) U (B \ A), which is the symmetric difference.
And D(A, B) = m^*(S(A, B)), which is the outer measure of the symmetric difference.
My issue in this calculation is this: outer measure of a set A is defined in terms of a countable covering of A with intervals I_k. How do you cover something in R^2 with intervals?
My guess on how to solve the problem: D(A, B) = m^*(S(A, B)) = m^*((0, 1]X[0, 1] U [1, 4]X(1, 10) U [0, 1]X[2, 10]) = m^*(0, 1]X[0, 1] + m^*[1, 4]X(1, 10) + m^*[0, 1]X[2, 10] = 1 + 27 + 8 = 36
The outer Lebesgue measure on [itex]\mathbb{R}[/itex] can be defined in terms of a countable covering by intervals. The outer Lebesgue measure on [itex]\mathbb{R}^2[/itex] can be defined in terms of a countable covering by rectangles. This should clear up your confusion.
If you want more information about this, you can read the following wikipedia article: http://en.wikipedia.org/wiki/Lebesgue_measure#Construction_of_the_Lebesgue_measure
