Compressed Sensing: Matching Pursuit
  • Context: Graduate
  • Thread starter Thread starter EngWiPy
    Compressed
The forum discussion centers on the Matching Pursuit algorithm used to solve the linear system Ax=b, where A is an M-by-N matrix, x is an N-dimensional sparse vector, and b is an M-dimensional vector. The algorithm operates by iteratively identifying the column of A that best matches b, projecting b onto this column, and updating b until a termination criterion is met. This geometric approach effectively reduces the dimensionality of the problem, allowing for efficient solutions to sparse representation challenges.
  • Understanding of linear algebra concepts, particularly matrix operations.
  • Familiarity with sparse vectors and their significance in data representation.
  • Knowledge of the Matching Pursuit algorithm and its iterative process.
  • Basic comprehension of projection methods in vector spaces.
  • Study the mathematical foundations of the Matching Pursuit algorithm.
  • Explore the geometric interpretation of projections in linear algebra.
  • Learn about alternative algorithms for sparse approximation, such as Orthogonal Matching Pursuit (OMP).
  • Investigate applications of Matching Pursuit in signal processing and data compression.
Researchers, data scientists, and engineers working in fields such as signal processing, machine learning, and data compression who require efficient methods for solving sparse linear systems.
EngWiPy
Hi,
I need a geometric explanation for this algorithm: Suppose we have the system Ax=b, where A is and M-by-N matrix, x is N-dimensional s(<<N)-sparse vector, and b is M-dimensional vector. There is an algorithm called Matching Pursuit to solve the above system efficiently:
1- Find the column of A that best match b.
2- The projection of b along that direction is removed and an updated b is obtained.
3- Repeat 1 and 2 until some termination criterion is met.
How these 3 steps solve the above system of linear equations?
Thanks in advance
  • · Replies 45 ·
