How thick is the frozen layer of ice on top of a pond?
The discussion revolves around determining the thickness of the frozen layer of ice on a pond, given specific temperature conditions at the ice surface and the pond's bottom. The problem involves concepts from thermal conductivity and heat transfer in the context of phase changes between ice and water.
  • Participants explore the equilibrium conditions necessary for the ice layer, questioning the temperature at the water/ice interface. There are attempts to set up equations for heat flow and temperature, with some participants suggesting simplifications regarding the area and resistivity of materials.
The discussion is active, with participants raising questions about the assumptions made regarding the temperature at the ice/water junction. Some guidance has been provided on setting up equations, but there is no clear consensus on the correct temperature at the junction, leading to further exploration of the problem.
There is a discrepancy between participants' assumptions about the temperature at the ice/water interface and the answer provided in a reference booklet, which adds complexity to the discussion. The problem is framed within the constraints of a homework assignment, emphasizing the need for careful consideration of thermal properties and equilibrium conditions.
nik jain
The temperature at the bottom of a pond of depth L IS 4°C. The temperature of the air , just above the layer of ice frozen at the pond surface is -2°C.
THE THERMAL CONDUCTIVITY OF ICE IS THREE TIMES THAT OF WATER
The thickness(X) of the frozen layer of ice must be-
Q= k*A*dQ/dx
K(ice)A(T-{-2})/X = K(WATER)A(4-T)/L where T is the temp. just below the ice layer
3K(WATER)A(T-{-2})/X = K(WATER)A(4-T)/L
FROM WHERE TO GET THE ANOTHER EQUATION
If the pond is in equilibrium so that the ice is neither growing nor melting, what can you say about the temperature at the water/ice interface?
So, how to solve this problem ?
Assume equilibrium. Write equations for heat flow and temperature that reflect the equilibrium conditions (which in this case are particular temperatures that need to be met at various places).
You can probably ignore the area aspect of the problem and just assume a linear dependence on the thickness for the heat resistance of the materials; since you won't need any particular values for the heat resistivities, just call the resistivity of ice ##\rho## so that a layer of thickness T will have heat resistance ##R_{ice} = \rho##T. What then would be the resistivity of water, and its resistance for a layer W thick?
I think it is safe to take the temperature at the ice/water junction to be 0 celsius
The equation you need is
dQ/dT = kA(dθ/dx)
How can we take the temp. at the junction to be 0°C
But by the ans. given in the booklet , the temp. at the junction is coming -1°C.
If the temperature at the water/ice interface was less than the freezing point for water then the ice would still be growing. If the temperature at the water/ice interface was greater than the freezing point for water then the ice would still be melting. Neither of those situations would be an equilibrium condition.
THANKS to you all for the help..
  • · Replies 17 ·
10K
