Effects of Increased Frequency on Output Voltage from a Step-Down Transformer
  • Thread starter Thread starter yousuf21
The discussion revolves around the effects of increasing the frequency of the main voltage from 50 Hz to 60 Hz on the output voltage and frequency of a step-down transformer connected to the main supply. The scope includes theoretical implications and practical considerations related to transformer operation under varying frequency conditions.
  • One participant queries the effects on output voltage and frequency when the main voltage frequency increases, expressing confusion about the implications.
  • Another participant prompts further exploration by asking what the original poster thinks might happen, indicating an interest in the reasoning behind potential outcomes.
  • A different participant emphasizes safety considerations, suggesting that a step-down transformer should only be used if one side of the mains is grounded and the plug is polarized, while also mentioning various factors affected by frequency changes such as output voltage and core losses.
  • Another participant notes that an automatic voltage regulator (AVR) in a generator set should maintain the voltage level independently of frequency changes.
  • One participant speculates that the original poster's situation likely involves an appliance designed for 50 Hz mains being tested on a 60 Hz supply.
Participants express differing views on the implications of frequency changes on transformer performance, with no consensus reached on the specific outcomes or effects.
Participants have not fully explored the assumptions regarding transformer design and operation under different frequencies, nor have they resolved the implications of core losses and reactive input current changes.
Individuals interested in electrical engineering, transformer design, and the effects of frequency on electrical systems may find this discussion relevant.
yousuf21
Hi everyone,
I have a query in my mind that what will happen when frequency of main voltage(220 V ac) increases from 50 to 60(or more) accidentally.What will be effect on output voltage(and frequency) from a step-down transformer connected next to main supply cable for power supply circuit?
Plz please answer my question
Hi yousuf21! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
It's a good question. What do you think might happen? and why? :wink:
If I had some idea than why should have I ask here? Seriously I'm confused:confused:
Use a step-down transformer only if one side of the 220 mains is a good safe ground, and if the 220 ac plug is polarized.
Examine the effect of the frequency change on the transformer output voltage, input inductance, reactive input current, excitation B field, and core losses.
The generator set will have an AVR (automatic voltage regulator) this operates independently of the frequency so should maintain the voltage at the correct level.
I'm thinking the situation is probably of an electrical appliance designed for 50Hz mains that OP is tempted to try operating off 60Hz mains.
  • · Replies 25 ·
