How Can Kepler's 3rd Law and Related Equations Be Applied to Orbital Mechanics?
  • Thread starter Thread starter forestmine
    Law
The discussion revolves around Kepler's 3rd Law and its application in orbital mechanics, particularly focusing on the relationships between the period of orbit, semi-major axis, and the masses involved in one-body and two-body problems. Participants seek clarification on various equations related to elliptical orbits and escape velocity.
  • The original poster attempts to understand the implications of Kepler's 3rd Law, questioning the meaning of negligible mass in the one-body problem and the applicability of the two-body problem to planetary orbits. They also explore the equations for velocity at perihelion and aphelion, and the conditions under which to use them. Other participants provide insights into the derivation of these equations and the definitions of variables involved.
Participants are actively engaging with the equations and concepts, offering clarifications and corrections to each other's reasoning. Some guidance has been provided regarding the use of expressions for perihelion and aphelion distances, and the relationship between kinetic and potential energy in the context of escape velocity.
There is an acknowledgment of the original poster's background, indicating they are navigating complex concepts without prior foundational courses. This context may influence the depth of understanding and the nature of questions raised.
forestmine
I don't have any particular problems I need help with. I'm just trying to wrap my head around some of the equations and their meanings. Any clarification would be great!
We have from Kepler's 3rd Law the following:
The period squared is proportional to the semi-major axis cubed.
Or,
P^2 = ((a^3)4*pi^2)/GM
and this equation in particular is the one body problem, where the mass of the body rotating around the sun is negligible in comparison to the sun, so M is the mass of the sun? If so, what's negligible mass?
And the two body problem would be the same thing, but,
((a^3)4*pi^2)/G(M+m)
Would the two-body problem apply for a planet's elliptical orbit around the sun?
From there, there is the equation for velocity along an elliptical orbit:
v^2 = GM (2/r - 1/a)
M in this case is the mass of the particular body whose velocity we are calculating? Say, the mass of the Earth?
And then there are these equations, which I'm a bit confused about.
Velocity at perihelion: v^2 = (GM/a)(1+e/1-e)
Velocity at aphelion: v^2 = (GM/a)(1-e/1+e)
So, if I'm given the eccentricity of the ellipse, I ought to use one of the last two equations, depending on whether it's at perihelion or aphelion? If a specific eccentricity is not given, I'm assuming I can use the equation v^2 = GM (2/r - 1/a), where r is a specified distance of either perihelion or aphelion?
And one last question. If the general equation for escape velocity is given by:
v=(2MG/r)^1/2
can I apply it in this form for elliptical orbits? If so, is M in this case again the mass of the body from which a particle or object is attempting to escape, and r is the distance out to that object?
Hopefully this is somewhat clear!
Thanks in advance!
Can anyone help clear this up?
This is a result that comes straight out of the virial theorem or mechanical similarity, I can never remember the names of these things.
It can be used for any 1/r potential, or 1/r^2 force law system!
It states that for a potential that goes as r^k the time between any two points separated by a length d on the trajectory are like
[itex]t \approx d^{1-\frac{k}{2}}[/itex]
Or,
If m << M (which is what's meant by the mass of the planet being negligible compared to the mass of the star) then you can replace m+M with just M (i.e. the total mass of the system is dominated by the mass of the star). Since this is totally the case in our solar system, the first equation would work just fine. That's useful, because it means that if you can measure the period and semi-major axis of some satellite object that is much smaller than the thing that it is orbiting, then you can figure out, to a good approximation, the mass of the thing that it is orbiting.
I'm sure that if you plugged in the expression for the distance of aphelion or perihelion (in terms of eccentricity) into "r" in the first equation, then you would be able to derive the last two equations. Try it.
v=(2MG/r)^1/2
Thanks in advance!
As you yourself have stated, this is the general equation for escape velocity. This means that it applies generally. Yes, of course M is the mass of the body being escaped from, and r is the starting distance of the object that is trying to escape. You can see that easily if you just derive the expression for the escape velocity.
Thanks for the replies.
I apologize for perhaps missing some of the more obvious things. I jumped into this higher level astronomy class before having taken any introductory courses, and so derivations are often skipped over, assuming we should already know those. I'll have to work through them myself.
I follow everything except:
"I'm sure that if you plugged in the expression for the distance of aphelion or perihelion (in terms of eccentricity) into "r" in the first equation, then you would be able to derive the last two equations. Try it."
Am I correct in that the expression for the distance of perihelion is r_p=a(1-e) and for aphelion, r_a=a(1+e).
Plugging one of these expressions into the expression for velocity along an elliptical orbit, I'm having trouble with the simple derivation.
v^2 = GM(2/a(1-e) - 1/a)
v^2 = GM [(2a - 1+e)/a(1-e)]
And from there I'm not sure how to arrive at the equation for velocity at perihelion?
(I realize I should have posted this in the general astronomy section...sorry!)
I think that you just made a slight error when taking a(1-e) as the common denominator for the two fractions you're adding. The numerator of the first fraction remains unchanged, since its denominator is *already* a(1-e). Therefore, your expression on top should just be (2 - 1 + e), NOT (2a - 1 + e).
To derive escape velocity, set the kinetic energy of the object equal to its gravitational potential energy. Then solve for the speed, v. The reason for this is that the object is trapped in a "well" of depth -GM/r, (which tops out at 0 energy at infinity). In order to "escape" to infinity, it must have at least this amount of kinetic energy to start with (enough to make it to the top of the well). Otherwise, it will reach zero speed at a finite distance away (i.e. it will still be partially within the well -- its kinetic energy will have been entirely converted to potential energy at a level that is still below zero). Then it will begin to fall back in (albeit very very slowly if it makes it quite far out).
Ok, it's all much clearer to me now.
Thank you for the help! I really appreciate it.
  • · Replies 16 ·
