Understanding Inverse Functions: How to Find f^-1(y)
  • Thread starter Thread starter sonya
    Function
The discussion revolves around understanding how to find the inverse of a function, specifically when given a function f(x) and asked to determine f^-1(y). Participants explore the relationship between a function and its inverse, questioning the steps involved in the process.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the method of swapping x and y to find the inverse function. There is a question about whether solving the original equation for y is equivalent to finding the inverse. One participant seeks clarification on the notation and terminology used in the context of inverse functions.
Some participants have provided insights into the process of finding inverse functions, including the importance of reversing operations. There is an indication that one participant has gained clarity on the topic, while another has expressed understanding after initial confusion.
There is mention of different methods for finding inverse functions and the acknowledgment that not all functions can be easily inverted. The discussion also touches on the definition of logarithmic functions as inverses of exponential functions.
sonya
if ur given a function f(x) and ur asked to find f^-1(y)...r u supposed 2 solve ur original eqn for y and then take the inverse of that? or isn't that just the same thing neways?...
What language precisely is that?
Anyway-
I don't know exactly how you have been taught to find inverse functions- there are several ways to arrive at the same result.
The way I like is this: Swap x and y.
Yes, that's it: If f(x)= y then f-1(y)= x.
If f(10)= 0 then f-1(0)= 10.
If f(x) is given by y= f(x)= 3x- 4 then the inverse function is given by x= 3y- 4.
Oh, there is one tiny other thing you might want to do:
Since we prefer to write f(x)= ... or f-1(x)= ...,
you might want to solve for y!
Since x= 3y- 4, 3y= x+ 4 and y= f-1(x)= (x+4)/3.
Notice the key point: what f(x) "does", f-1(x) "undoes".
Where f(x) is "multiply by 3 then add 4", f-1(x) says "subtract 4, then divide by 3". Each step is reversed ("add 4" instead of "subtract 4" and "divide by 3" instead of "multiply by 3") and the order is also reversed. Of course: when I go to work in the morning, I put on my shoes, then go out the door, then lock the door behind me. When I come home in the evening, I first UNlock the door, then go in through the door, then take off my shoes. Each operation is reversed and the order is reversed.
Of course, you can't always "solve" for the inverse function.
If f(x)= ex then f-1(x)= ln(x) because that is the way ln is DEFINED- as the inverse function to ex.
ok..i think i understand now but a quick question
where x = 3y -4 that can also be called f-1(y) rite?
o..never mind that question...i get it now
thx a lot!
  • · Replies 17 ·
  • · Replies 17 ·
