Time to decelerate over a given distance
  • Thread starter Thread starter asp55
    Time
The problem involves calculating the time it takes for an object to decelerate from an initial velocity of 95 m/s to a stop over a distance of 8 km. The subject area pertains to kinematics and motion under constant acceleration.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply kinematic equations but encounters a negative time result, prompting questions about the correctness of their approach. Some participants suggest revising the formula used and emphasize the need for a second equation to solve for both acceleration and time. Another participant shares a different formula to find acceleration and subsequently calculates time.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the correct application of kinematic equations, and alternative approaches are being considered. There is no explicit consensus yet on the best method to solve the problem.
Participants are working under the assumption that the deceleration is constant, and there is a need to clarify the relationship between distance, initial velocity, acceleration, and time. The original poster's confusion regarding negative time indicates a potential misunderstanding of the equations involved.
asp55
Alright, so the problem I'm working on is basically as such:
An object with an initial Velocity of 95m/s slides horizontally, constantly losing velocity. After traveling 8 km it comes to a stop.
How long did the object take to travel 8 km.
So here's how I went at it:
δx = v0 + .5at^2
δx+v0 = .5(δv/t)t^2
2(δx+v0) = v(t^2)/t
2(δx+v0)/δv = (t^2)/t
2(δx+v0)/δv = t
Then I plugged in:
δx = 8000m
v0 = 95m/s
δv = -95m/s
Which returned t = -170.421s (Which I thought was odd to begin with, as how can one have a negative value for time.)
But I tried plugging that into my initial equation to see that it all worked out but instead of getting δx = 8000m I got δx = 8190m
So obviously there is a flaw in my logic SOMEWHERE. I just don't know where.
Help please!?
You appear to be using a 'special character' that shows up on my reader as ? .
Was it δ ?
Your first error is not "logic" but the wrong formula: δ x= v0t+ (1/2)at2. You forgot the "t" multiplying v0.
Making that change, assuming that "constantly losing velocity" mean that the decelleration is constant, δx= v0t+ (1/2)at2. You are given that x= 8000 m and that v0= 95 m/s. That leaves a and t as unknowns. Since there are two unknowns, you need a second equation: in that same time, t, the velocity reduces from 95 to 0 so -95= at is the second equation.
You need to solve 8000= 95t+ (1/2)at2 and -95= at.
Substitute t= -95/a as you did and solve the quadratic equation.
Ahh, so I did. Thank you.
I used the formula
Vf^2 = Vo^2 +2ad
I found a from this. which was -0.564m/s^2
From there I went to the formula d= Vo+1/2at^2 and solved for time.
In which I got about 167 seconds.
  • · Replies 22 ·
