Are two magnets twice as strong as one?
  • Context: Undergrad
  • Thread starter Thread starter cuffbertt
    Magnets
The discussion centers on the strength of neodymium magnets, specifically those rated at 3.1kg (approximately 30N) pull strength. A user tested two magnets attached to each other and found that they separated at 24N, leading to confusion regarding the expected force of 60N. The conclusion drawn is that attaching two magnets does not result in a combined pull strength, as the actual force required to separate them was less than anticipated, suggesting that the manufacturer's ratings may be optimistic.
  • Understanding of neodymium magnet specifications
  • Familiarity with tensile testing machines
  • Basic knowledge of force measurement in Newtons
  • Concept of magnetic attraction and pull strength
  • Research the properties of neodymium magnets and their pull strength ratings
  • Learn about tensile testing methods and equipment
  • Investigate the effects of magnetic field interactions when combining magnets
  • Explore manufacturer specifications and testing standards for magnets
Engineers, physicists, hobbyists working with magnets, and anyone interested in understanding the practical applications and limitations of neodymium magnets.
cuffbertt
Hi there,
I am having trouble with a project I am working on... hopefully someone will be able to help me. :)
I have some neodymium magnets that are rated as having a ”pull" strength of 3.1kg each, I am assuming that this means that you can attach it to a metallic surface and it would take 3.1kg (or about 30N) to pull it off.
If I was to attach one magnet to another, and try and pull them apart, would they pull towards each other with 30N of force each, resulting in 60N being required to pull them apart?
I have done some testing with a tensile testing machine, and the results have confused me somewhat, the two magnets separated at 24N. I have come to the conclusion that either I am hideously wrong in my assumption and have now got to rectify my mistake, or the manufacturer has been somewhat generous with their quotes.
I've spent some time looking online and I cannot seem to find an answer to this, so if anyone is able to help I would be grateful: D
Well, there's a simple way to test this, isn't there? :wink: Next time, use a single magnet attached to a static object, and measure the amount of force. If it's not more or less equal to 12N (you can measure that one again if you want to), then no, attaching those two magnets together doesn't require twice the force to separate. :smile:
  • · Replies 16 ·
  • · Replies 42 ·
