New Reply
San Onofre steam generator tubes leaking - why?
Share Thread
Mar23-12, 02:30 PM   #1
Hi,
San Onofre, menioned durring the Japan crisis, is leaking and corroding pipes fast:
http://www.scpr.org/blogs/news/2012/...-indefinitely/
http://sciencedude.ocregister.com/20...-units/167503/
What is going on- any ideas?
Take care
Jens Jakob
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Mar23-12, 04:02 PM   #2
Engineering 2012
Recognitions:
Gold Membership Gold Member
Steam generator tubes are leaking thinning .
This was a big problem stateside 1n 1970's.
Chemistry of water on secondary side is extremely important.
We measured impurities in parts-per--billion. One cup of tap water was enough to cause a shutdown to flush the steam generators, i know because one of our technicians used a cup of tapwater to top off a level instrument..... once.
Metallurgy was important also. Copper contributed to corrosion.
We replaced the admiralty brass tubes in condenser with titanium, and feedwater heaters with stainless steel.
These lessons were learned almost forty years ago. Our replacement generators from Westinghouse-Tampa are doing fine.
So - what's going on now? That's REAL good question.
First question pops to mind is "Where did Mitsubishi procure the metal for the tubes in those replacement steam generators?"
Second is "How's the plant's water chemistry ?"
It'll be interesting to follow this one.
Edited first line. sorry.
Mar23-12, 04:25 PM   #3
http://www.clipsyndicate.com/video/p...clips&wpid=752
The San Onofre plant replaced its steam generators in 2010; it is almost certain this is a manufacturing defect.
Mar23-12, 04:28 PM   #4
Recognitions:
NRC discussion for background. We don't know the cause yet, so I will not speculate.
http://www.nrc.gov/reading-rm/doc-co...steam-gen.html
Mar23-12, 05:09 PM   #5
Admin
Quote by jensjakob View Post
Hi,
Take care
Jens Jakob
The fact that these are replacement SG's and the tubes failed during the first cycle of operation would implicate 1) a manufacturing defect or 2) a problem with installation.
SCE replaced SGs in SONGS2 during 2009.
24 February 2009
Two replacement steam generators have been delivered for the second unit of Southern California Edison's (SCE's) San Onofre Nuclear Generating Station (SONGS). Mitsubishi Heavy Industries (MHI) made the components.
http://www.world-nuclear-news.org/ne....aspx?id=24719
04 October 2010
Mitsubishi Heavy Industries (MHI) has delivered two replacement steam generators for the third unit of Southern California Edison's (SCE's) San Onofre Nuclear Generating Station (SONGS).
MHI said that the replacement steam generators delivered for SONGS 3 are among the world's largest, each measuring approximately 20 metres in length, seven metres in diameter and weighing some 580 tonnes. Each of them contains about 10,000 heat transfer tubes.
http://www.world-nuclear-news.org/C-...3-0410105.html
'Why' is the question - indeed! There is an ongoing investigation. It must be determined if any corrosion (intergranular stress-corrosion) and/or cracking is occurring, and if it is initiated on the primary or secondary side.
I believe the material is Inconel 690, which is supposed to be superior to Inconel 600. However, Inconels are notoriously tricky alloy systems.
Mar23-12, 07:36 PM   #6
"The company has received overseas orders for 31 units, mainly from North America and Europe. "
Hmmm - could be interesting to track those and compare corrosion.
Mar23-12, 11:03 PM   #7
Recognitions:
Updated Daily Event Report:
http://www.nrc.gov/reading-rm/doc-co...0120319en.html
Preliminary Notification and Update
http://pbadupws.nrc.gov/docs/ML1203/ML12032A243.pdf
http://pbadupws.nrc.gov/docs/ML1207/ML12075A219.pdf
NRC press release for AIT:
http://pbadupws.nrc.gov/docs/ML1208/ML120800460.pdf
Mar23-12, 11:18 PM   #8
Recognitions:
More info at the SONGS website:
http://www.songscommunity.com/news.asp
Confirms Unit 2 S/G replacement in 2009 and Unit 3 in 2010. The following link is good info on the testing methods being used:
http://www.songscommunity.com/docs/Test_Inspections.pdf
Mar23-12, 11:42 PM   #9
Recognitions:
Picture of Steam Generator (MHI):
http://www.mhi.co.jp/en/products/det...generator.html
Unit 3 S/G had leakage before delivery. Note that this was not tube leakage so current problems may not be directly related.
http://mdn.mainichi.jp/mdnnews/news/...dm058000c.html
If there is a manufacturing problem, Mitsubishi has already delivered over 100 steam generators around the world.I am less worried about the 31 on order.
Mar24-12, 07:07 AM   #10
Admin
Quote by NUCENG View Post
The article states
According to the NRC documents, Mitsubishi Heavy discovered a 5 inch (12.7 centimeter) long crack in the dissimilar metal weld between the divider plate and the channel head of the steam generator of the unit 3 reactor during its routine visual inspection in March 2009.
If that is the replacement S/G, that's rather troubling. In 2009, that SG would have been at the Mitsubishi shop - ostensibly before shipment. Or did Mitsubishi inspect the older in-service SG, which was replaced in 2010?
A crack in the divider plate is not bad as long as it doesn't propagate. A breach in the divider plate would allow leakage from the hot leg to the cold leg, thus by-passing the SG tube bundle. It is still within the primary system.
From the description, it sounds like the crack was at the edge of the divider plate where it joins the vessel (channel) head.
Mar24-12, 07:15 AM   #11
Recognitions:
Quote by Astronuc View Post
The article states If that is the replacement S/G, that's rather troubling. In 2009, that SG would have been at the Mitsubishi shop - ostensibly before shipment. Or did Mitsubishi inspect the older in-service SG, which was replaced in 2010?
I understand the crack was on the Unit 3 replacement S/G and was repaired before shipment and installation in 2010.
Mar24-12, 07:55 AM   #12
Admin
That would seem to be what the article implicates. I was hoping for confirmation.
Nevertheless, I'm puzzled about the crack, and also about welding dissimilar metals. I would expect the vessel shell to be line with stainless steel, and the divider plate to be made of the same stainless steel. Certainly if one welds a low carbon stainless steel to a high carbon steel, cracking can be an issue.
I'm curious about their process and procedures, since the procedures should be such that cracking is prevented/avoided.
I'd like to know if the Inconel tubes are cracking (which would imply either poor material and/or poor fabrication practice) or leaking about the fitup at the tube sheet (which would imply a poor process).
Nevertheless, it is very troubling that such failures occur in something that is designed to last 20 to 30 years.
Original SGs were supposed to last the life of the plant (40) years, and if possible now 60 years. They represent a substantial capital cost, and the economic models, which I studied at university, never included SG replacement. After I finished by undergrad, I learned about how Inconel 600 components (and certainly welding materials) were failing prematurely.
Primary water chemistry, and in some cases, secondary water chemistry are certainly factors.
Mar24-12, 08:27 AM   #13
Recognitions:
And anytime you open a system there is a chance for loose parts or materials to enter a system. Flow induced vibration can cause wear and tear. A few years ago replacement condensate pumps for a nuclear plant were exposed to road grime and sludge during shipment because penetration seals were not properly installed. I too am concerned this has developed so soon after S/G replacement and that is likely why NRC sent the AIT. I am not a welding or S/G expert, but if I find additional information I will post it. We should learn more when the NRC AIT has their exit meeting.
Mar24-12, 08:48 AM   #14
Engineering 2012
Recognitions:
From Nuceng's http://pbadupws.nrc.gov/docs/ML1207/ML12075A219.pdf
Continuing inspections of 100% of the steam generator tubes in both Unit 3
steam generators discovered unexpected wear, including tube to tube as well as tube to tube
support structural wear.
and http://www.nrc.gov/reading-rm/doc-co...0120319en.html
Steam generators do experience some wear during the first year of operation but the level of tube wear at Unit 3 is unusual.
Chemistry problems can deposit solids in the support to tube annulus and squeeze the tubes.
But tube-to-tube wear sounds more like a vibration issue arising from mechanical design.
It's hard to believe mechanical vibration trouble after this many years experience making Steam Generators.
As you said, it'll be interesting to see what they find.
Mar24-12, 09:16 AM   #15
Admin
Quote by jim hardy View Post
The chemistry practices are pretty standard these days. There could be an issue with commissioning a fresh surface.
Replacement generators may have higher flow rates. I can't remember if there was a plant uprate with the steam generator replacement.
Tube wear after one cycle of operation would be troubling. Despite experience, designer make 'improvements' that sometime may introduce performance problems. There was a case of two BWRs* in which new advanced turbines developed cracks in one of the late stages in the LP turbine. Subsequent CFD reveal a design flaw. The CFD analysis (which is very mature these days) should have been part of the initial design process.
*Hamaoka 5 and Shika 2 off line after turbine vane failures
http://www.neimagazine.com/story.asp?storyCode=2038314
High cycle fatigue (either mechanical (FIV) or thermo-mechanical) is a possibility if the frequency is in the acoustic range (10-1000s Hz) with 3.156E7 s/yr.
Mar24-12, 09:44 AM   #16
Recognitions:
San Onofre Units 2 and 3 have both got approved Margin Uncertainty Recovery Power Uprates of 1.4% in 2001.
Mar24-12, 09:58 AM   #17
Admin
That's enough time to incorporate into the current replacement design. In terms of uprate, I was thinking more along the lines of an extended or stretch uprate with 5+% increase in reactor/plant output.
Mitsubishi is a Westinghouse licensee, and they have probably replaced more W-SG than CE SGs. The large CE plants (mostly 16x16 fueled) typically use 2 steam generators - with one hot leg and two cold legs. They are therefore typically larger than W-SGs. Could that be a factor?
New Reply
Similar discussions for: San Onofre steam generator tubes leaking - why?
Thread Forum Replies
Steam Generator problem Engineering, Comp Sci, & Technology Homework 3
Steam power generator Engineering Systems & Design 10
Steam Generator take me off grid. Mechanical Engineering 10
biomass steam generator Engineering Systems & Design 2
