Mathematica - 2D plot for function of 2 vars?
The discussion revolves around creating 2D plots for a function of two variables, f(a,b), specifically focusing on how to visualize f(a,b) against a for various discrete values of b. The context includes technical aspects of using Mathematica for plotting.
  • One participant inquires about generating multiple 2D plots of f(a,b) vs a for specific values of b, expressing difficulty in achieving this with 2D plotting functions in Mathematica.
  • Another participant suggests a solution by defining a new function f1(b) that mirrors f(a,b) and using the Plot function to create the desired plots for specified b values.
  • A further suggestion is made to automate the plotting process by using a Table function to generate a series of plots for a range of values, which could simplify the process for larger datasets.
  • A participant expresses appreciation for the proposed improvement in automating the plotting process.
Participants appear to agree on the proposed methods for creating the plots, with no evident disagreement on the solutions offered.
The discussion does not address potential limitations or assumptions regarding the function f(a,b) or the specific implementation details in Mathematica.
Users of Mathematica interested in plotting functions of two variables, particularly those looking for methods to visualize data efficiently in 2D.
dcnicholls
I have a function of two variables, f(a,b). I want to create a series of 2D plots (on the same plot) of f(a,b) vs a, for a=1 to 10, for a set of discrete values of b (e.g. b=10,20,50,100).
Is there a simple way to do this? Plot3D works, but I cannot find how to do it in 2D.
DN
Solved: Define a second function f1(b) with the same formula as f(a,b), and use:
Plot[{f1[10],f1[20],f[50],f[100]},{a,1,10}]
Does the job.
DN
Also if you want to automoate it more you can make it a table:
Plot[Table[f1,{i,1,100,5}],{a,1,10}]
Makes a table of f1 as i goes from 1 to 100 by 5. Easier if you want a lot of them.
Thanks, useful improvement.
