What is the lift force on a car's roof at 100km/hr with an area of 3.9m^2?
  • Context: Undergrad
  • Thread starter Thread starter salpal243
    Force Lift Lift force
The discussion revolves around calculating the lift force on a car's roof at a speed of 100 km/hr, specifically focusing on the implications of air density and the car's roof area of 3.9 m². Participants explore the principles of aerodynamics and the conditions necessary for lift generation in this context.
  • One participant expresses confusion about calculating the lift force on a car's roof under specified conditions.
  • Another participant argues that lift cannot be generated by a flat roof alone without some mechanism to deflect air, stating that speed alone is insufficient for lift on a flat plate parallel to the wind.
  • It is noted that the Bernoulli principle does not apply in this scenario, as the pressure of the air remains ambient regardless of the car's speed, provided the speed is sub-sonic.
  • A participant suggests that the shape of the car, particularly the windshield, contributes to lift by deflecting air, and that understanding the car's profile is essential for determining lift versus speed.
  • Further discussion questions why the Bernoulli principle is deemed inapplicable, with an explanation that the air's speed does not result from a pressure transition affecting the flat plate.
Participants do not reach a consensus on the application of the Bernoulli principle or the conditions necessary for lift generation on a flat roof, indicating multiple competing views remain in the discussion.
Participants highlight limitations in understanding the aerodynamic effects on a flat roof, including the need for specific shape profiles and the conditions under which Bernoulli's principle may or may not apply.
salpal243
the question I am stumped on is "What is the lift force on the roof of your car that has an aera of 3.9m^2 if you are driving 100km/hr? use 1.17kg/m^3 for density of air
There would have to be something deflecting air away from a flat roof in order to produce lift. Speed alone isn't going to create lift on a flat plate parallel to the relative wind. Bernoulli principle doesn't apply here. You could place a flush mounted static port in a flat roof to measure pressure of the moving air outside and it would indicate the same ambient pressure if the car was stopped or moving (as long as speeds are reasonably sub-sonic).
For a real car, the windshield deflects the air away from the roof, and the overall shape of most cars is similar to a common wing and tends to produce some lift. You'd have to know the profile shape of the car, similar to knowing the profile of an airfoil, in order to determine the lift versus speed.
Why does Bernoulli principle not apply? My first thought was that it would indeed create a significant difference in pressure...
Because the speed of the air wasn't the result of a transition from higher pressure to lower pressure. In this case, the assumption is that the pressure of the air is ambient. It doesn't matter what the speed of the flat plate is if the flat plate isn't interacting with the air (assume the flat plate doesn't change the speed of the air, ignoring any skin friction effects). This why static ports that are just small openings in the side of an aircraft's fuselage (at a point where the air's speed isn't being changed) can sense the ambient pressure of the air, regardless of the speed of the aircraft (as long as speed is sufficiently below the speed of sound).
  • · Replies 30 ·
  • · Replies 20 ·
  • · Replies 95 ·
  • · Replies 17 ·
9K
