Bullets, block, and conservation of linear momentum
The discussion focuses on a physics problem involving a block and two bullets, where the block has a mass of 4.75 kg and the bullets each have a mass of 0.023 kg. The bullets collide with the block simultaneously, and their speeds are related by v1 = (2/3)v2 = 324 m/s. The key concept to solve the problem is the conservation of momentum during inelastic collisions, which allows for the calculation of the block's speed immediately after the collision.
  • Understanding of conservation of momentum in inelastic collisions
  • Knowledge of kinetic friction and its coefficient (uk = 0.455)
  • Basic algebra for solving equations
  • Familiarity with mass and velocity concepts in physics
  • Study the principles of conservation of momentum in inelastic collisions
  • Learn how to calculate the final velocity of a system post-collision
  • Investigate the effects of kinetic friction on moving objects
  • Explore detailed examples of similar physics problems for practice
Students studying physics, particularly those focused on mechanics and collision problems, as well as educators looking for examples of inelastic collisions and momentum conservation.
bphy
Hello,
I've been stuck on this problem and would really appreciate if someone could help me:
A block of mass MB = 4.75 kg is initially at rest on a level rough surface for which the
coefficient of kinetic friction is given by uk = 0.455 . Two bullets of equal mass
Mb = 0.023 kg are moving horizontally in opposite directions with speeds related by
v1 = (2 / 3)v2 = 324 m / s when they collide with the block simultaneously and become
embedded in the block, as represented in the image below. Do the following:
a) Calculate the speed of the block just after the collision. You may assume the
conservation of mass during the collision.
http://i44.tinypic.com/6riz3c.jpg
can someone please explain how to solve this in step by step detail? Or at least how to find the equation for the velocity just after collision?
bphy said:
Hello,
Hi bphy, Welcome to Physics Forums.
I'm afraid that we cannot solve this for you step by step -- that would be doing your homework for you, which is against the rules. What we can do is provide a hint or suggestion that you can use to get started. Show us the attempt you make as a result and then we can make further comments and suggestions.
So to begin with, I'd suggest you investigate (in your text or notes) the concept of conservation of momentum for inelastic collisions.
  • · Replies 31 ·
18K
