New Reply
Find wavelength of a quantum of electromagnetic radiation
Share Thread
Mar26-12, 08:03 PM   #1
A quantum of electromagnetic radiation has
an energy of 0.877 keV.
What is its wavelength? The speed of light
is 2.99792 × 10
8 m/s, and Planck’s constant
is 6.62607 × 10−34J · s.
Answer in units of nm
2. Relevant equations
E=hf
v=fλ
... λ=v/(E/h)
3. The attempt at a solution
When i solved, i got 1.413728e-9 nm... I have checked my units. can some just help and point me in the right direction
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar26-12, 08:29 PM   #2
v is usually written as c when one speaks of the speed of light in vacuum. Also, the double fraction reduces to:
[tex]
\frac{c}{\frac{E}{h}} = \frac{h \, c}{E}
[/tex]
For this answer, you need to know the conversion factor between an electron-volt (eV) and a joule as energy units. Do you know it?
Mar26-12, 08:32 PM   #3
Quote by Dickfore View Post
[tex]
[/tex]
Yes i did convert it but i still got it wrong
Mar26-12, 08:33 PM   #4
how did you convert it, and what did you get?
Mar26-12, 08:36 PM   #5
I did it again and i got 1.414E-8 ... and i think that is in meters. Am i right??
so that means that the answer is14.14nm
_______________________________________________________________________ _
I used plancks constant in eV's. Its on the ap equation sheet
Mar26-12, 08:41 PM   #6
I didn't get that. What did you get for the energy in joules?
Mar26-12, 08:45 PM   #7
1.405109518e-16 J
Mar26-12, 08:51 PM   #8
This is correct. Now:
[tex]
\frac{h \, c}{E} = \frac{6.626 \times 10^{-34} \, \mathrm{J} \cdot \mathrm{s} \times 2.998 \times 10^8 \, \mathrm{m} \cdot \mathrm{s}^{-1}}{1.4051 \times 10^{-16} \, \mathrm{J}}
[/tex]
The product and ratio of the mantissas, gives:
[tex]
\frac{6.626 \times 2.998}{1.4051} = 14.14
[/tex]
The exponents sum up to [itex]-34 + 8 - (-16) = -10[/itex]. You may read off the units from the above fraction fairly easily.
What should the answer be in scientific form?
Mar26-12, 08:58 PM   #9
so in nm, it would be 1.414
Mar26-12, 09:03 PM   #10
yes, except that you need to use as many significant figures, as there are in variable with the least number of significant figures given in the problem. Fundamental constants are usually known to a lot of significant figures.
Mar26-12, 09:21 PM   #11
Thank You
New Reply
Similar discussions for: Find wavelength of a quantum of electromagnetic radiation
Thread Forum Replies
Heat is electromagnetic radiation OR heat is __spread by__ electromagnetic radiation? Classical Physics 2
Max wavelength of CMB radiation Cosmology 4
Electromagnetic Induction vs. Electromagnetic Radiation Classical Physics 17
Wavelength of an Electromagnetic wave General Physics 4
Wavelength of electromagnetic radiation Chemistry 2
