New Reply
Slip systems in HCP metals
Share Thread Thread Tools
Mar27-12, 04:09 AM   #1
Hello,
I'm having looots of trouble trying to find out the operative slip systems of hcp metals. the slip system is {001}<100> and in my notes it says that there are 3 slip systems and I don't see why!! I'm guessing there's only one slip plane the (001) or (0001), and three directions. But the three directions I'm calculating are [100]. [010] and [001], which in the 4-indices system are: [2 -1 -1 0], [-1 2 -1 0] and [0 0 0 1]. Is this correct????
If it is correct, then only the first two are contained in the (001) plane, so there should be only 2 SLIP SYSTEMS!!!
I'm lost!
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Mar28-12, 06:31 PM   #2
Admin
{001}<100> would apply to cubic systems. One can slip on the cube faces, the diagonal in 2-dimensions (0,0,0) to (0,1,1), or the superdiagonal from (0,0,0) to (1,1,1).
Normally for hcp, there are 4 indices.
For hcp planes, there are the basal planes, then prismatic planes and pyramidal planes.
http://books.google.com/books?id=TX7...page&q&f=false
Mar29-12, 02:15 AM   #3
Yes, i know that for hco you usually use 4 indices, but you can also talk about 3, since these can converted into the 4-inices system! Eg: {001} is the same as {0001}. what i dont see is how do I know which directions are equivalente in hcp and therefore belong to the same family?
Regards.
Mar29-12, 02:39 AM   #4
The fourth index is only added (between the 2nd and 3rd) to make like planes look like.
(H K L) contains all the necessary information, but often (H K (-H-K) L) is written.
(1 0 0) would then become (1 0 -1 0).
(1 0 -1 0), (0 -1 1 0), (-1 1 0 0) are all in the same star, which is easy to see in the 4-index notation.
(1 1 -2 0) is in a different star with (-2 1 1 0), (1 -2 1 0).
Mar29-12, 05:29 AM   #5
Quote by M Quack View Post
right, so basically if i change the order or sign of the indices, they still belong to the same family???
then why do [100], [010] and [110] (in the 3 indices system) belong to the same family in hcp?!?!?!?!?!?!?!??!?! don't seee why [110] should belong to the same one as the other two!!!!
Mar29-12, 06:47 AM   #6
Admin
Quote by Chemist20 View Post
[110], [101], [011] is a different system than [100], [010], [001]. Look at the number of zero indices, and nonzero indices.
In hcp, basal planes are {0001}, primary prism planes {10-10}, and pyramidal planes {10-11}. Another pyramidal plane is {11-21}
Mar29-12, 06:53 AM   #7
Yes, just remember that the c-axis (00L) or (000L) has a completely different symmetry.
For HCP, you can change the sign, but this is not true for all hexagonal crystal classes.
It is counter-intuitive because the two in-plane vectors a* and b* are not at right angles.
Just take a piece of paper, draw a hexagon and sketch the vectors. You will see.
Mar29-12, 08:26 AM   #8
Yeap I see. But i still dont know why in my book it says that the three directions in the <100> family in hcp metals are [100] [010] and [110].....
Mar29-12, 11:56 AM   #9
You actually get 6 directions corresponding to the 6 corners of the hexagon. But HCP systems have inversion symmetry, so (110) is the same as (-1 -1 0) and this reduces to just 3 directions.
Mar31-12, 04:02 AM   #10
I'm lost.. can you explain please?????
Mar31-12, 04:47 AM   #11
(1 1 0) you are looking at the top of the plane, (-1 -1 0) you are looking at the bottom of the plane.
If the plane is a symmetry plane, then that makes no difference. This is the case in HCP metals.
In lower symmetry systems that might make a difference - say above the plane there are OH groups attached, and below F ions.
Mar31-12, 05:25 AM   #12
Yes, I do understand that. But why is the -1 -1 0 direction in the same family as 1 0 0 for hcp????? That's what I don't get...
Apr1-12, 03:05 AM   #13
The defining feature of all hexagonal crystal structures is a 3-fold rotation axis along c, i.e. if you rotate the whole crystal by 120 deg about the c-axis you end up with the same crystal structure.
If you rotate (1 0 0) by 120 deg, you get (0 1 0).
If you rotate (0 1 0) by 120 deg, what do you get?
Apr1-12, 12:03 PM   #14
Quote by m quack View Post
the defining feature of all hexagonal crystal structures is a 3-fold rotation axis along c, i.e. If you rotate the whole crystal by 120 deg about the c-axis you end up with the same crystal structure.
( 0 0 1) ?????????
Apr1-12, 12:38 PM   #15
Nope. Try again :-)
(0 0 1) is the c-axis. You are rotating about the c-axis. How can any vector perpendicular to the axis or rotation become parallel to it?!?
Apr2-12, 11:09 AM   #16
Nope. Try again :-)
woops okay. so im guessing the answer is 110 but i don't know why.!!!!!!
Apr2-12, 03:12 PM   #17
Oh well.. :-)
Let [itex]\vec{a}=\left(\begin{array}{c}0\\ 0\\1 \end{array} \right)[/itex]
Let [itex]C_3 = \left( \begin{array}{ccc} c & -s & 0 \\ s & c & 0\\ 0 & 0 & 1 \end{array} \right) [/itex]
With s=sin(120 deg) and c= cos(120 deg).
Calculate [itex] \vec{b} = C_3 \vec{a} [/itex] and [itex] \vec{d} = C_3 \vec{b} [/itex]
Write d as linear combination of a and b.
Show C_3^3 =1 and C_3 c = c with c=(0 0 1)
New Reply
Tags
hcp, metals, slip, systems
Thread Tools
Similar Threads for: Slip systems in HCP metals
Thread Forum Replies
Materials Science Help - Slip Systems & Resolved Shear Stress Materials & Chemical Engineering 18
Close Packed Planes and Slip Systems Engineering, Comp Sci, & Technology Homework 1
pitch of net slip and plunge and trend of net slip of a fault using stereonets Earth 1
Role of Metals in Living Systems Chemistry 3
