Describe the thermodynamic system of a wire.
The discussion revolves around the thermodynamic analysis of a wire, particularly focusing on the work done during its stretching and the application of the first law of thermodynamics. Participants are examining the relationships between tension, internal energy, and free energy in the context of thermodynamic systems.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the derivation of equations related to the work done on the wire and the implications of the first law of thermodynamics. Questions arise regarding the definitions and roles of various thermodynamic quantities, such as tension and temperature.
The discussion is active, with participants providing insights and seeking clarification on the derivations presented. Some have offered guidance on terminology and notation, while others are probing deeper into the foundational concepts of thermodynamics as they relate to the problem at hand.
There are mentions of potential confusion regarding the notation used for temperature and tension, as well as the need for clarity on the derivation steps that some participants feel are missing. The discussion reflects a collaborative effort to unpack complex thermodynamic relationships without reaching a definitive conclusion.
curiousvortex
http://i.imgur.com/2WKCR.jpg
Potentially: L(final) = L[1 + tau/(YA) + alpha(T - To)]
Frankly I have no idea where to begin.
Hi! In my opinion the answer is the following: the work done on the wire in order to stretch the wire of [itex]\delta l[/itex] is [itex]\delta W=t \delta l[/itex] where t is the tension of the wire (notice that \delta W is positive if [itex]\delta l[/itex] is positive, opposite behaviour with respect to the pressure and analogous behaviour with respect to the surface tension); indeed, one should reasonably make a positive work in order to stretch the wire; the first law of the thermodynamics in this situation is
[itex]\delta U= T \delta S+ t \delta l[/itex]
Since F=U-TS (I mean with F the Helmoltz free energy) i obtain
[itex]\delta F=- S \delta T+ t \delta l[/itex]
and so
[itex]\frac{\partial F}{\partial l}|_T=t[/itex]
[itex]\frac{\partial F}{\partial T}|_l=-S[/itex]
Well, you left out quite a few steps but it's right.
BTW my textbook uses "A" instead of "F" for the Helmholz function. And, if I may suggest, don't use t for temperature. Use T. t is almost always time.
t is the tension and T is the temperature :)
Anyway, can you tell me please what are the steps I left out? Thanks,
Francesco
Sorry, that got by me completely.
You gave an equation, whence did it come? How about starting from the 1st law?
I'm sorry, but I think that I don't understand: let me go into the details of the derivation, also covering well-known thermodynamics result; is the equation you are talking about
[itex]\delta U=T\delta S+t\delta l[/itex] ?
If so, then I think that this is just the first law for the system we are talking about (with [itex]\delta[/itex] I mean an infinitesimal change; well, to be rigorous, an infinitesimal reversible change); for every thermodynamic system we are supposed to have a function of state U (the internal energy) and to be able to define an ordered work ([itex]t\delta l[/itex]) and a disordered work ([itex]T\delta S[/itex]); then, by definition, I define
[itex]F=U-TS[/itex] and then
[itex]\delta F=\delta U-(\delta T)S-T(\delta S)=-S\delta T+t\delta l[/itex].
Did I understand what you have asked or did you mean something else?
Maybe I'm being picky but
dU - SdT -TdS = -SdT + tdL was not obvious to me. Admittedly I did not identify 'orderd' and 'disorderd' work as tdL and TdS respectively. In fact I don't remember coming across those terms at all except that certainly they make sense, qualitatively at least.
You can do without that concept by
dU = dQ + dW 1st law, dw > 0 here.
dU = TdS + dW
dW = tdL
so dU = TdS + tdL
dF = dU - TdS - SdT
dF = TdS + tdL - TdS - SdT
dF = tdL - SdT
and the partials fall out as you indicated.
rude man said:
[itex] <br /> You can do without that concept by<br /> dU = dQ + dW 1st law, dw > 0 here.<br /> dU = TdS + dW<br /> dW = tdL<br /> so dU = TdS + tdL<br /> dF = dU - TdS - SdT<br /> dF = TdS + tdL - TdS - SdT<br /> dF = tdL - SdT<br /> and the partials fall out as you indicated.[/itex]
[itex] <br /> Hello.<br /> <br /> dQ=TdS for every thermodynamic system that undergoes an infintesimal reversible transformation, as it is well known form basic thermodynamics.<br /> <br /> dW>0 doesn't make sense by itself; you should specify if dl is greater or smaller than 0.<br /> <br /> dW=tdl is analogous to -pdV in a usual gas system; if you want to build a simple (the simplest?) model where you can see this, you can imagine the wire as composed by N+1 very small masses disposed on a row, each distant d from the next ones. The fact that the wire has a tension t means that every particle A exerts on the next one B a force t in the direction B "with the arrow pointing from B to A". we want to stretch this wire of a length dl; then, we can move the particle identified by the integer n of the following length : dl((n-1)/N). You can now easily conclude.<br /> <br /> <blockquote data-attributes="" data-quote="rude man" data-source="post: 3839278" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> rude man said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> [itex]\delta F=\delta U-(\delta T)S-T(\delta S)=-S\delta T+t\delta l[/itex].<br /> <br /> Maybe I'm being picky but <br /> dU - SdT -TdS = -SdT + tdL was not obvious to me. Admittedly I did not identify 'orderd' and 'disorderd' work as tdL and TdS respectively. In fact I don't remember coming across those terms at all except that certainly they make sense, qualitatively at least. </div> </div> </blockquote><br /> <br /> take two generic functions f(x,y), g(x,y) (sufficiently regular): then, by some mathematical analysis course,<br /> [itex]d(f g)=g(\frac{\partial f}{\partial x}dx+\frac{\partial f}{\partial y}dy)+f(\frac{\partial g}{\partial x}dx+\frac{\partial g}{\partial y}dy)[/itex]<br /> <br /> then we obtain the wantedd result if x=S, y=T, f(S,T)=S, g(S,T)=T.<br /> <br /> dU - SdT -TdS =TdS+tdl - SdT -TdS=-SdT + tdL<br /> <br /> <br /> Francesco[/itex]
  • · Replies 36 ·
  • · Replies 0 ·
