Solve a+b+c=0 given a+(1/b)=b+(1/c)=c+(1/a)
  • Thread starter Thread starter Perpendicular
The discussion revolves around the equations a + (1/b) = b + (1/c) = c + (1/a) and the goal of proving that either a = b = c or a + b + c = 0. Participants are exploring algebraic relationships and manipulations within the context of these equations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to derive relationships from the given equations, questioning how to manipulate them to reach the desired conclusions. Some are exploring specific cases, such as assuming a = b = c, while others are investigating the implications of a + b + c = 0.
The discussion is ongoing, with various approaches being suggested. Some participants have offered algebraic manipulations and substitutions, while others express uncertainty about the implications of their findings. There is no explicit consensus yet, but several lines of reasoning are being explored.
Participants note that the symmetry of the problem may suggest a symmetric proof. There are also mentions of independent equations and the challenge of deriving identities from the assumption a + b + c = 0.
Perpendicular
Given : a + (1/b) = b + (1/c) = c + (1/a)
prove a=b=c or a+b+c = 0
I know that a^3 + b^3 + c^3 = 3abc is sufficient proof to derive the above two relations asked for..but I cannot get the expression up to there.
I tried to see if a+b+c = 0 logically leads to the given equation, but no luck so far.
What am I missing ?
Assume that the equation is true, and assume that first a solution is a=b=c try replacing a with b:
b+1/b = b+1/c=c+1/b
And c should also be equal to b. So replace again:
c+1/c = c+1/c = c+1/c
True true true. So indeed that is a solution. Do the same for a+b+c=0 <=> a = -b-c
and find that the equation is true
What am I missing ?
You have two independent equations:
a + (1/b) = b + (1/c)​
and
a + (1/b) = c + (1/a)
Solve the second one for c, and plug that into the first one.
Do some algebraic manipulation. One solution should be a = b .
The other solution is more complicated. I assume it should lead to a+b+c=0
hmm … the solution is symmetric, so i'd expect the proof to be symmetric also :redface:
if we subtract the three equations in pairs, i can get to abc = ±1, or a = b = c :smile:
and it might help to use that if p/q = r/s = t/u, then they all equal [Ap+Br+Ct]/[Aq+Bs+Cu]
Putting a+b+c = 0 the equation is not becoming an identity...
What else have you tried?
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 21 ·
