Is My Calculation of the Divergence of a Vector Correct?
  • Thread starter Thread starter meteorologist1
    Divergence Vector
The discussion revolves around calculating the divergence of a radius vector in Cartesian, cylindrical, and spherical coordinates. The original poster presents their findings and expresses confusion regarding the results obtained for cylindrical and spherical coordinates.
  • Participants explore the divergence calculation in different coordinate systems, questioning the correctness of the original poster's answers. Some participants provide their own calculations and seek clarification on the methods used.
The discussion is active, with participants sharing their calculations and questioning the assumptions made in the original poster's approach. Some guidance has been offered regarding the divergence in Cartesian coordinates, while the cylindrical and spherical cases remain under scrutiny.
There is a noted concern about the behavior of unit vectors in cylindrical and spherical coordinates, which may affect the interpretation of vector fields. Participants also discuss the implications of constants in vector components and how this relates to uniformity in vector fields.
meteorologist1
Hi, I'm doing a problem of finding the divergence of a radius vector from the origin to any point in Cartesian, cylindrical, and spherical coordinates. The answers look kind of strange to me. I just want to make sure what I did was correct.
To find: [tex]\nabla\cdot \vec{r}[/tex]
Cartesian: r = (x, y, z). I got the answer to be 3.
Cylindrical: r = (rho, phi, z). I got the answer to be 3 + 1/rho
Spherical: r = (r, theta, phi). I got the answer to be 3 + (1/r sin(theta))(sin(theta) + theta cos(theta) + 1).
Thanks.
3 ?! Could you show how you got to that answer please?
That is correct since [tex]\vec{\nabla} \cdot \vec{r} = \frac{\partial x}{\partial x} + \frac{\partial y}{\partial y} + \frac{\partial z}{\partial z} = 3[/tex]
marlon
The answer "3" is very good.I'm curious about the other 2 answers.
Daniel.
all answers should be the same...
For the Cartesian:
[tex]\nabla\cdot \vec{r} = (\vec{i}\partial/\partial x + \vec{j}\partial / \partial y + \vec{k}\partial / \partial z) \cdot (\vec{i} x + \vec{j} y + \vec{k} z) =[/tex]
[tex]\partial/\partial x (x) + \partial/\partial y (y) + \partial/\partial z (z) = 1 + 1 + 1 = 3[/tex]
The other two cylindrical and spherical, I did the same way. But I used the [tex]\nabla\cdot \vec{r}[/tex] for cylindrical and spherical which I referred to in a handbook.
Could you show me how to get "3" for the cylindrical and spherical? Thanks.
Thanks.
In cylindrical coordinates:
[tex]\vec r = \rho \hat \rho + z \hat z[/tex]
and
[tex]\nabla \cdot \vec v(\rho,\phi,z) = \frac{1}{\rho}\frac{\partial}{\partial \rho}(\rho v_{\rho})+\frac{1}{\rho}\frac{\partial v_{\phi}}{\partial \phi}+\frac{\partial v_z}{\partial z}[/tex]
For some vector function [itex]v=\langle v_{\rho},v_{\phi},v_z \rangle[/itex]
In spherical coordinates:
[tex]\vec r = r\hat r[/tex]
and
[tex]\nabla \cdot \vec v(r,\theta,\phi)=\frac{1}{r^2}\frac{\partial}{\partial r}(r^2v_r)+\frac{1}{r\sin \theta}\frac{\partial}{\partial \theta}(\sin \theta v_{\theta})+\frac{1}{r\sin \theta}\frac{\partial v_{\phi}}{\partial \phi}[/tex]
for some vector function [itex]v=\langle v_r,v_{\theta},v_{\phi} \rangle[/itex]
Both give 3 as well:
[tex]\nabla \cdot \vec r(\rho,\phi,z) =\frac{1}{\rho}\frac{\partial}{\partial \rho}(\rho \rho)+\frac{\partial z}{\partial z}=\frac{1}{\rho}2\rho+1=3[/tex]
[tex]\nabla \cdot \vec r(r,\theta,\phi)=\frac{1}{r^2}\frac{\partial}{\partial r}(r^2 r)=\frac{1}{r^2}3r^2=3[/tex]
You can't use the divergence in cylindrical or spherical coordinates when r=0 though.
Thanks very much. It looks like the reason I got the wrong answers is because I got the r vectors wrong in cylindrical and spherical coordinates. I need to get this straight.
I would like to ask another question related to these two coordinates:
In cylindrical coordinates,
If [tex]\vec{A} = a\vec{\rho} + b\vec{\phi} + c\vec{z}[/tex] where a, b, c are constants, is [tex]\vec{A}[/tex] a constant vector?
Similarly in spherical coordinates,
If [tex]\vec{A} = a\vec{r} + b\vec{\theta} + c\vec{\phi}[/tex] where a, b, c are constants, is [tex]\vec{A}[/tex] a constant vector?
your question doesn't make any sense, if a,b,c are constant, sure A is constant. If not, it's not...
I'm asking because when I converted A to Cartesian coordinates, it doesn't look constant anymore. Another way of asking the question is: Is [tex]\vec{A}[/tex] a uniform vector field?
Not exactly and not always true.U need the unit vectors (basis vectors) to be constant in all systems of coordinates.Par éxample,write the second law of dynamics for a free body moving on a spere in cartesian coordinates and in spherical coordinates.
[tex]\vec{F}=m\vec{a} =0[/tex]
Tell me if u notice something weird...
Voilà.My point exactly.It all depends on whether the g_{ij}'s are constant or not.
Daniel.
his question is, in the following case...
is A constant or not, sure we assume [tex]\vec{\rho}, \vec{\phi}, \vec{z}[/tex] define as usual which IS constant...
What do u mean,"the usual way"??If they are constant and the components are constant,then the whole cevor is constant,of course.
Daniel.
I think confusion has arised because of the way the question is posted.
I think you meant to say: "Is [itex]\vec A[/itex] a constant vector field. The answer is no.
This is because spherical and cylindrical coordinates have at least one unit vector which is not constant. The Cartesian coordinate system is the only one for which all three unit vectors are constant.
It's for example easy to see for the field:
[tex]\vec A(r,\theta,\phi) = \hat r[/tex]
This is a radial field. The magnitude is 1 everywhere, but the direction changes. It points along the +x-axis in the point (1,0,0), but it points along the +y direction in the point (0,1,0).
Thanks all for the clarification, but, in the spherical coordinates system, how the second part went to zero?
I mean this whole part:
[/tex]
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 24 ·
