Find Stretched Length of Spring - 8.5kg Board at 50°
  • Thread starter Thread starter rasputin66
    Angle Spring
The problem involves a board weighing 8.5 kg, held at a 50° angle by a spring with a spring constant of 184 N/m. The objective is to determine how much the spring is stretched from its unstrained length while considering the forces acting on the board and the conditions for equilibrium.
  • Participants discuss the forces acting on the board, specifically gravity and the spring force, and question how to incorporate the angle into their calculations. There is an attempt to apply the formula for spring extension but uncertainty remains regarding the angular components and equilibrium conditions.
The discussion is ongoing, with participants exploring the forces involved and questioning the conditions for equilibrium. Some guidance has been provided regarding the importance of considering both gravity and the spring force, but clarity on how to integrate the angle into the calculations is still needed.
Participants express confusion about the angular aspect of the problem and the conditions for rotational equilibrium, indicating potential gaps in the information needed to solve the problem effectively.
rasputin66
A 8.5 kg board is wedged into a corner and held by a spring at a 50.0° angle, as the drawing shows. The spring has a spring constant of 184 N/m and is parallel to the floor. Find the amount by which the spring is stretched from its unstrained length.
(The picture shows a spring sticking out of the wall horizontally, and it is attached to one end of the board. The spring is holding the board up from falling flat on the floor. So the board is pulling on the spring.)
I know how to do some spring questions, but I don't know how to plug in the angle in this question. Please help! I know I need to find N to find x.
00000 <~~ spring
| / <~~~ board
m= 8.5 kg
angle= 50 degrees
k= 184 N/m
What forces act on the board? What are the conditions for equilibrium?
Gravity? And the spring?
They equal zero? I think I'm missing something. Like how to figure in this angular business.
x = (mg/k)
x=(9.8x8.5)/184
x=0.565 m<~~~ not right
Yes, those are the two most important forces.
What is the condition for rotational equilibrium?
