Comparing ωxr and rxω in Vector Calculations
The discussion focuses on the differences between using ωxr and rxω in vector calculations, emphasizing that the order of the cross product significantly affects the direction of the resultant vector. While the magnitude remains constant, reversing the order results in a vector pointing in the opposite direction. The context of the problem is crucial, particularly when applying physical laws within a right-handed coordinate system, as it dictates the appropriate order for the cross product.
  • Understanding of vector mathematics
  • Familiarity with cross product operations
  • Knowledge of right-handed coordinate systems
  • Basic principles of physics related to vector applications
  • Study the properties of vector cross products
  • Learn about right-handed versus left-handed coordinate systems
  • Explore applications of cross products in physics
  • Investigate vector calculus techniques for advanced calculations
Students and professionals in physics, mathematics, and engineering who require a clear understanding of vector operations and their implications in various applications.
Icetray
Hi guys,
I just wanted to know when to use ωxr and when to use rxω when we're making vector based calculations. I realized that when reversed te calculations tend to differ a lot.
Thanks for the help in advance!
[tex]AxB = -BxA[/tex]
It's strictly convention. The magnitude of the vector you get will be the same either way, however, it will be in the opposite direction. You need to think about the problem asked to figure out which way you should perform the cross product.
Icetray said:
Hi guys,
They result in a different direction for the resultant (diametrically opposite direction, actually). The cross product is a mathematical operation that is order dependent.
There is no way to answer your question without knowing the context; If a physical "law" is involved then the order is specified to result in the correct direction given that the vectors involved are specified in a standard "right handed" coordinate system.
  • · Replies 18 ·
  • · Replies 44 ·
