Calculating Distance of an Electron Moving in a Plane Using Derivatives
  • Thread starter Thread starter courtrigrad
    Electron
The problem involves calculating the rate of change of distance from the origin for an electron moving in a plane, with its coordinates defined in terms of exponential functions of time.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the correct formula for distance from the origin, with one suggesting the use of the distance formula and another emphasizing the need for the square root in the calculation. There is also mention of derivatives and potential simplifications using hyperbolic functions.
The discussion is ongoing, with participants clarifying the correct approach to finding the distance and its derivative. There is some back-and-forth regarding the proper formulation of the distance and the necessary steps to derive it.
Participants are navigating the definitions of distance and derivatives, with some expressing uncertainty about the use of hyperbolic functions in their calculations. There is an indication that not all participants may be familiar with certain derivative concepts.
courtrigrad
An electron moves in a plane so that at time t its coordinates are
x = a( e^t + e^-t) and y = b(e^t - e^-t) . How fast is its distance from the origin changing?
My solution:
Let Y be the distance from the origin and the point
Then using distance formula I get
Y = [[a( e^t + e^-t) ^2] + [[b(e^t - e^-t)^2]
Do I just find derivative of this?
y is not the distance between origin and point, r=sqrt(x^2+y^2), do the derivative of r and you will see the answer
isnt that what i have??
one more things, sinhx=(e^x-e^-x)/2 coshx=(e^x+e^-x)/2, hope tis will make the calculation simpler, IF you have not learned the derivative of these yet, just forget it...
Nope,u miss the square root...
Daniel.
  • · Replies 19 ·
