New Reply
Taylor expansion in physics
Share Thread Thread Tools
Apr1-12, 03:01 AM   #1
i am very confuse how my profs always use taylor expansion in physics which somehow doesn't follow the general equation of
f(x) = f(a) + f'(a)(x-a) + 1/2! f''(a)(x-a)2 and so on...
like for example, what is the taylor expansion of x - kx where k is small
it was given as something like
x - kx f'(x) + (1/2) k2 x2 f''(x) + ...
is this taylor expansion? but there is no 'about which point, i.e, a=? '
i don't even understand how the first term x is gotten. f(a) = x??
please help thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr1-12, 04:36 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi quietrain!
Quote by quietrain View Post
… something like …
hmm … but not exactly like!
the (x)s should be a, and the x at the start should be f(a)
(and k = x - a)
Apr1-12, 05:03 AM   #3
Recognitions:
Hi quietrain! :)
Suppose you expand f(a-kx).
You would get: f(a-kx) = f(a) - kx f'(a) + (1/2) k2 x2 f''(a) + ...
Now replace "a" with "x"...
Apparently you've got a typo in the first term.
EDIT: Oops, TM got here first!
Apr1-12, 05:34 AM   #4
Mentor
TT and ILS have done a great job of guessing what you meant, but you should probably explain what function you really wanted to expand. (The Taylor expansion of x-kx is x-kx, so that's probably not it ).
Apr2-12, 04:39 AM   #5
Recognitions:
Fix x, and let g(k) = f(x-kx). Expand as g(k) = g(0) + k*g'(0) + (k^2/2)*g''(0) + ...
g(0) = f(x), g'(k) = -x*f'(x-kx) --> g'(0) = -x*f'(x), g''(k) = x^2*f''(x-kx) --> g''(0) = x^2*f''(x), etc.
RGV
Apr2-12, 05:29 AM   #6
hi everyone thanks for helping
but the taylor expansion was for x-kx
or perhaps only -kx was expanded?
but anyway it was given as x - kx f'(x) + ...
Quote by I like Serena View Post
Hi quietrain! :)
with regards to the above, how did you get that formula?
because i only know this f(x) = f(a) + f'(a)(x-a) + 1/2! f''(a)(x-a)2 as the general formula?
in any case, does it mean if i want to expand say 1 + kx
then it would be f(1+kx) = f(1) + kx f'(1) + ...
so f(1) is 1 + k(1) = 1+k?
then f'(1) is k? then where do i put my 1 since i don't have x
also does it mean f'' onwards are all 0?
Quote by Ray Vickson View Post
RGV
YES! this is the one. so it was an expansion about the small value k ? and not x? i see.
but in particular, how did you get g'(k) and g'(k)?
is it through the chain rule differentiation?
thanks!
Apr2-12, 05:54 AM   #7
Recognitions:
Okay, let's start with the formula you have:
f(x) = f(a) + f'(a)(x-a) + 1/2! f''(a)(x-a)2 + ...
but let's rewrite it with y instead of x to eliminate the ambiguity between the x's.
So:
f(y) = f(a) + f'(a)(y-a) + 1/2! f''(a)(y-a)2 + ...
You want to expand f(x-kx).
To do this, first define y=x-kx, and define a=x.
Then replace all occurrences of y by (x-kx), and replace all occurrences of a by x.
What do you get?
Edit: Btw, an alternative formula for Taylor expansion is: f(x+h)=f(x) + h f'(x) + 1/2! h2 f''(x) + ...
Apr2-12, 06:27 AM   #8
Mentor
Your terminology is inaccurate. What you're doing here is to expand ##f## around the point 1 in its domain. The expansion of 1+kx (i.e. the function ##x\mapsto 1+kx##) around 0 (the point I'd assume you have in mind unless you specify another one) is just 1+kx.
Apr2-12, 07:30 AM   #9
So:
What do you get?
oh, we can just define a as x?
does it mean i can define a as -kx or -k also?
but i thought a is the point that we evaluate the taylor expansion on?
am i right to say if i taylor expand on a point say x =1 for a curve graph. then as my orders of taylor expansion become greater, the approximation is better too?
Apr2-12, 07:33 AM   #10
Quote by Fredrik View Post
oh... do you mean since 1+kx is a straight line, so at the point 0, it is just 1 + kx ?
so if i had a curve, would taylor expansion ( approximation? ) make more sense here?
that means the first term of the expansion gives me a straight line, the 2nd makes it more curve, the 3rd makes it even more like the original curve function?
does it then mean i cannot taylor expand things like 1+kx? i have to expand only curves?
Apr2-12, 07:34 AM   #11
Recognitions:
"x" and "a" are just letters.
You can replace them by anything you want, as long as you do so consistently and do not mix letters up.
(Note that "x" has 2 different meanings in your problem statement. That's why I introduced "y" - to eliminate one of the two.)
In your original formula f(x)=f(a)+f'(a)(x-a)+...
the expansion is around "a".
In the formula f(x-kx)=f(x)+f'(x)((x-kx)-x)+...= f(x) - kx f'(x) + ...
the expansion is around "x".
Apr2-12, 08:20 AM   #12
Recognitions:
If you expand 1+kx around x=0, you are effectively defining f(x)=1+kx, and a=0.
So using your formula to expand it, you get:
f(x)=1+kx
f'(x)=k
f''(x)=0
f'''(x)=0
So:
f(x)=f(a)+f'(a)(x-a)+1/2! f''(a)(x-a)2+...
f(x)=f(0)+f'(0)(x-0)+1/2! f''(0)(x-0)2+...
f(x)=1+k(x-0)+1/2! 0.(x-0)2+ 0 + ...
f(x)=1+kx
Hey! But you already had that! :)
Apr2-12, 02:47 PM   #13
Recognitions:
I think your expression was copied wrong, or had a misprint: you should have written
f(x) - kx f'(x) + (1/2) k2 x2 f''(x) + ... [with f(x) as the first term, not just x]. You did say the expression was "something like...", which says to me that you were not sure.
RGV
Apr3-12, 08:21 PM   #14
alright thanks everyone!
New Reply
Thread Tools
Similar Threads for: Taylor expansion in physics
Thread Forum Replies
Taylor expansion in 3-D Calculus 2
a little help with this Taylor expansion please? Advanced Physics Homework 4
taylor expansion of x^x Calculus & Beyond Homework 2
Taylor expansion Calculus & Beyond Homework 0
Taylor expansion Calculus 0
