What are the forces exerted on a diving board when a person stands on the tip?
  • Thread starter Thread starter PeachBanana
    Board Forces
The discussion focuses on calculating the forces exerted on a diving board when a 62 kg person stands at its tip. The force exerted by support B is calculated as F (B) = 607.62 N using the equation F = ma. To find the force at support A, the torque balance equation must be applied, ensuring that the sum of torques is zero due to the absence of rotational acceleration. Additionally, a force balance equation is necessary to confirm that the sum of vertical forces equals zero, reflecting no translational acceleration.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of torque and rotational equilibrium
  • Familiarity with force balance equations
  • Basic principles of static equilibrium
  • Study torque balance equations in static systems
  • Learn about static equilibrium and its applications in physics
  • Explore examples of force balance in various mechanical systems
  • Review detailed calculations involving forces and torques in real-world scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and design of structures subject to static loads.
PeachBanana
Calculate the forces F (A) and F (B) that the supports exert on the diving board of the figure when a 62 kg person stands at its tip. Ignore the weight of the board. Assume that x-axis points upward.
F = ma
F (B) = (62 kg)(9.8 m/s^2) = 607.62 N
F (A) = (x kg)(9.8 m/s^2) = ______ N
I'm having trouble as to what to use for the mass. I was thinking 62 kg but it wouldn't make sense for them to be the same if A is farther away.
The only force that is equal to (62 kg)*g is the weight of the person. To solve for the other forces, you need to use the torque balance equation. In other words, use the fact that the sum of torques on the board is 0, since it has no rotational acceleration.
You'll also need to use a force balance equation. The sum of vertical forces on the board should be 0, since it has no translational acceleration.
  • · Replies 35 ·
  • · Replies 23 ·
  • · Replies 21 ·
