Why Does Food Stick More to a Hot Pan Than a Cold One?
  • Context: Undergrad
  • Thread starter Thread starter bobsmith76
    Food Hot
The discussion centers around the phenomenon of food sticking to a hot pan compared to a cold one, exploring the underlying reasons for this behavior. Participants examine chemical interactions, molecular motion, and the effects of temperature on food adhesion to cookware materials.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that food sticking is due to chemical bonds, such as weak van der Waals forces or covalent bonds, particularly with protein-rich foods forming complexes with metal atoms in the pan.
  • Another participant challenges the analogy made with nuclear fusion, emphasizing that nuclear reactions occur at much higher temperatures than those used in cooking.
  • A participant proposes that increased molecular motion at higher temperatures increases the likelihood of food molecules forming bonds with the pan, though they express uncertainty about the permanence of these bonds.
  • Another participant argues that the comparison between nuclear and chemical reactions is not particularly relevant, but acknowledges that increased atomic vibration with temperature is significant. They suggest that the stickiness may relate to changes in the chemical structure of proteins and the behavior of adhesives at elevated temperatures.
  • It is noted that sugar complexes may adhere to the pan when the water content decreases at the interface, indicating a possible interaction between temperature and moisture levels.
Participants express differing views on the mechanisms behind food sticking, with no consensus reached. Some focus on chemical bonding, while others emphasize the role of temperature and molecular motion.
Participants mention various types of bonds and interactions without fully resolving the distinctions between them. There is also uncertainty regarding the permanence of the bonds formed during cooking.
This discussion may be of interest to those exploring the chemistry of cooking, food science, or the physical principles of heat and adhesion.
bobsmith76
I found this explanation here:
Food that sticks is caused by chemical bonds that form between the food and the material of the pan - almost always a metal. These bonds may be relatively weak van der Waals forces or covalent bonds. Protein-rich foods are particularly prone to sticking because the proteins can form complexes with metal atoms, such as iron, in the pan.
But what it does not explain is that food does not stick to a pan when cold, but it does when hot. That's what I want to know. Here's my guess. It's the same reason why you need heat to take two helium and make Beryllium. Heat increases the odds of two helium sticking together because there is more motion and hence more probabilistic resources. When food gets heated the atoms move more and there is a greater chance of the atoms from the food and the metal coming nearer each other and forming a covalent or Van der Waals bond.
let me know if this is correct.
Science news on Phys.org
No, nuclear reactions and, in particular, fusion reactions do not take place at any where near "stove" temperatures! (You have to set off a fission bomb just to get the temperatures necessary for a fusion bomb to ignite.)
I know that, what I'm saying is that with molecules moving faster there is more chance that the molecules will bump up next to each and form a permanent covalent bond. I'm not sure if covalent or van der waals are permanent bonds. but that's my idea.
Nuclear and chemical reactions work under different conditions with regards to the electromagnetic force and the weak and strong force so the comparision is not especially enlightening, except for the part about greater atomic vibration with increase in temperature.
Perhaps the stickiness of cooked food is more related to how adhesives behave considering the chemical structure of the proteins in food is altered by elevated temperature. Note also that sugar complexes stick to the pan when the water content drops at the pan / sugar interface.
15K
  • · Replies 21 ·
  • · Replies 19 ·
20K
