New Reply
Pulley, Ramp with Moment of Inertia
Share Thread Thread Tools
Apr2-12, 01:53 AM   #1
http://imgur.com/ZkjXv
The given answers are (b) .309 m/s^2 (c) T1= 7.67N, T2=9.22N
2. Relevant equations
I_disc = .5(mass_disc)r^2
Sum of Torque = I α
a = r α
3. The attempt at a solution
We will define the system moving right and down as positive to get a positive acceleration.
The tension between mass 1 (2kg) and the pulley is T_1
The tension between mass 2 (6kg) and the pulley is T_2
Summation of Torque = I α = rT_2 - rT_1
plug in: α = a/r and I_disc = .5(mass_disc)r^2
into
I α = rT_2 - rT_1
to get
a(.5)(mass_disc) = T_2 - T_1
The summation of the forces in the x-direction for m1 is: F_x = m1(a) = T_1 - μ(m1)g
T_1 = (m1)a + μmg
How do you define the summation of the forces for m2 and get an expression for T_2?
My first attempt:
Sum of Forces for M2 in x direction:
F_x = (m2)a = T_2 - μ(m2)gcos30
T_2 = (m2)a + μ(m2)gcos30
is incorrect. This was done through rotating the system 30 degrees but the summation for mass 1 was not rotated therefore the equations are not consistent and apparently, wrong. What is the best way to do this?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr2-12, 02:38 AM   #2
[itex]T_1-μm_1g=m_1a .......1[/itex]
[itex]m_2Sinθ-μm_2Cosθ-T_2=m_2a .......2[/itex]
[itex]r(T_2-T_1)=Iα........3[/itex]
3 equations with 3 unknowns- a,T1 and T2
Rotating the system make it more complicated.
You should be consistent with direction of acceleration.
Apr2-12, 08:48 AM   #3
Quote by azizlwl View Post
The equation you gave for T_2 seems to be incorrect. Plugging in .309 for a yields a T_2 of -.725 which is incorrect
Apr2-12, 12:50 PM   #4
Bump? Can anyone give some insight?
Apr2-12, 02:41 PM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi kc0ldeah!
(try using the X2 button just above the Reply box )
Quote by kc0ldeah View Post
that's only tension and friction …
what about gravity?
Apr2-12, 08:39 PM   #6
Thousand apologies.
The second equation should be....missing g
[itex]m_2gSinθ-μm_2gCosθ-T_2=m_2a .......2[/itex]
New Reply
Thread Tools
Similar Threads for: Pulley, Ramp with Moment of Inertia
Thread Forum Replies
Moment of Inertia of a pulley Introductory Physics Homework 5
Moment of Inertia of a Pulley Introductory Physics Homework 4
Pulley system with Moment of Inertia Introductory Physics Homework 0
MI moment of inertia on pulley Introductory Physics Homework 2
Pulley & Moment of inertia Introductory Physics Homework 5
