Calculating Coefficient of Friction In the System
The discussion focuses on calculating the coefficient of friction between crates and a conveyor belt at a 30-degree angle. The initial calculation yielded a coefficient of friction (μ) of 1.73, derived from the pressing force and friction force equations. However, a correction was made indicating that the correct formula should be μ = 981N / 1699.14N, leading to a revised understanding of static friction. Participants emphasized the importance of solving the problem in variables before substituting numerical values to avoid errors.
  • Understanding of basic physics concepts such as forces and friction.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Knowledge of free body diagrams and their application in physics problems.
  • Ability to manipulate equations and solve for variables.
  • Study the derivation of the coefficient of static friction in various scenarios.
  • Learn how to construct and analyze free body diagrams effectively.
  • Explore the implications of angle of inclination on frictional forces.
  • Review common errors in physics calculations and how to avoid them.
Students in physics courses, educators teaching mechanics, and anyone interested in understanding frictional forces in practical applications.
junkie_ball
When the converyor belt was first installed safety checks were carried out to determine the limit of angle for safety. It was found that at an angle of 30 degrees the crates start to slip down.
Calculate the coefficient of friction between the crates and the belt? (Diagram as shown in the question attached) I also assume they are looking for the static coefficient not the slipping as the question isn't very clear?
Friction = Pressing Force x Constant
or μ= Pressing Force/Friction
Vertical force acting on the crate (H in my free body diagram)
H = Gravity x mass
H = 9.81 x 200
H = 1962N
Parallel downwards to the surface of the plane force acting on the crate (O in my free body digram)
O = H x Sin θ
O = 1962 x Sin 30
O = 981N
Therefore i can assume the friction force acting in the opposite direction to 'O' is 981N
Force acting into the surface of the plane (A in my free body diagram)
A = H x Cos θ
A = 1962 x Cos 30
A = 1699.14N
This is my pressing force.
To calculate the coefficient of friction between the crates and belt is
μ = 1699.14 / 981
μ = 1.73
This is my first attempt at calculating a coefficient do would really appreciate if someone could review this and check I'm on the right lines.
Max Static friction is given by (μs*normal force), normal force in your diagram is "A" so set O=A and solve for μs. Looks good, up until the end. You have 1699.14/981 flipped, should be 981/1699.14. However its best to solve the problem in variables first and then plug in your values at the end. In this problem (mg) drops out and it simplifies nicely.
Hi thanks for the reply i see where i mixed my final equation up. I took a quick glance at my course material and they have written the equation back to front. I'm starting to seriously worry about the quality of the course materials with the errors i have come across so far.
9K
10K
  • · Replies 24 ·
