Energy Dissipated in Loop (Magnetic Field)-
The discussion focuses on calculating the energy dissipated in a circular loop of wire with N turns, radius r, and resistance R, subjected to a time-varying magnetic field B(t) = B0e^(-t/tau). The participant derived the EMF using the formula EMF = -d/dt(flux) = -dB/dt * NA, leading to the expression for energy dissipation as dE/dt = (NA)^2 * (t/tau)^2 * (B^2)e^(-2t/tau). However, the participant initially made an error in differentiating the magnetic field, which was corrected through peer feedback.
  • Understanding of electromagnetic induction principles
  • Familiarity with the concepts of EMF and magnetic flux
  • Knowledge of calculus, specifically differentiation and integration
  • Basic understanding of electrical resistance and power calculations
  • Review Faraday's Law of Electromagnetic Induction
  • Study the derivation of the energy dissipated in resistive circuits
  • Learn about the time constant tau in RC circuits
  • Explore the effects of varying magnetic fields on induced currents
Students studying electromagnetism, physics educators, and anyone interested in understanding energy dissipation in electrical circuits influenced by magnetic fields.
The Head
Energy Dissipated in Loop (Magnetic Field)-- Please Help!
What is the energy dissipated as a function of time in a circular loop of N turns of wire having a radius of r and a resistance of R if the plane of the loop is perpendicular to a magnetic field given by
B(t)=B0e-t/tau
P=I^2*R=EMF^2/R
EMF=-d/dt(flux)=-dB/dt*NA
I first wanted to calculate the EMF, and since the B field varies, I found the derivative of the B field, times the number of turns times the area:
EMF=NA*(t/tau)Be^(-t/tau)
Then squaring this term and multiplying it by 1/R will equal the time-derivative of the energy dissipated
dE/dt = (NA)^2*(t/tau)^2*(B^2)e^(-2t/tau)
Bringing dt over and integrating from 0 to t I find (and substituting pi*r^2 for A):
E=(N*pi*r^2)^2*(B^2)(tau^2-e^(-2t/tau))(2t^2+2t*tau + tau^2)/(4R*tau)
This is not the correct answer, though.
Any help? Please!
Your derivative of the B field doesn't look right. Since you're taking the derivative w.r.t. time the t shouldn't be coming down from the exponent.
Oh-duh! Thank you--got it now.
  • · Replies 37 ·
