What Is the Velocity Change of a Fighter Plane in Horizontal Circular Motion?
  • Thread starter Thread starter nesan
    Velocity
The problem involves a fighter plane moving in a horizontal circular path at a constant speed, specifically focusing on calculating the change in velocity as it alters its heading over a given time period. The context includes concepts from circular motion and vector analysis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the importance of angular velocity in circular motion and suggest considering the relationship between angular and tangential speeds. There are inquiries about the representation of velocity vectors and how to calculate the change in velocity. Some participants express confusion about specific terms like angular velocity and tangential speed.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have offered guidance on considering angular velocity and vector subtraction for determining velocity change, while others are seeking clarification on fundamental concepts.
There is mention of a lack of familiarity with certain concepts such as tangential velocity, which may affect the participants' ability to engage fully with the problem. Additionally, the original poster notes a discrepancy between their calculations and the textbook answer.
nesan
a fighter plane is moving in a horizontal circular path at a constant speed, it takes 9.8 seconds to change its heading by one quarter of a circle from north to east, if the radius of the curvature is 2.0 x 10^3, find
d) the velocity change
v = d / t
d = square root ((2.0 x 10^3)^2 + (2.0 x 10^3)^2)
d ≈ 2828m
d / t = 288.6m/s
But the textbook says the answer is 4.5 x 10^2 m/s
I have no idea, in what other ways I can approach this. Help please. :( Pointing me in the right direction will do. ^_^ Thank you.
The plane didn't take a straight line from the starting position to the final position over the 9.8 seconds.
Instead, why not think first of the angular velocity, since the plane is describing a circle and you're essentially given the angle it goes through over the 9.8 seconds. If you have the angular velocity and the radius, what is the corresponding tangential speed?
After that, what are the two vectors that represent the starting velocity and final velocity? What's the change between them?
Can you explain a bit more on what you mean by angular velocity please? Thank you. :)
EDIT : We haven't learned about tangential velocity and such, could you please explain it in-terms of a beginner, please and thank you. :)
NVM got it.
distance / time = speed
square root (speed ^2 + speed ^2) = average velocity
Thank you. :)
How do you measure a distance if you're travel in a circle?
This must involve the arc distance along the circle.
Since the aircraft in flying in a circle, the angular speed is used.
But there's relation between angular and linear motion.
One of them velocity, ωr=v, where ω is angular speed dθ/dt(radian per second)
When you got the velocity at 2 points use vector subtraction to find the difference/change.
  • · Replies 38 ·
  • · Replies 67 ·
  • · Replies 26 ·
