Calculating Induced Current in a Solenoid-Loop Circuit
The discussion centers on calculating the induced current in a solenoid-loop circuit involving a cylindrical solenoid of 30 cm length and 8 mm radius with 400 turns of wire, and a rectangular loop of dimensions 3 cm by 2 cm with a resistance of 190 ohms. The induced current is determined using the formula I = emf/R * [1-e^{-(R/L)t}], resulting in a calculated current of approximately 0.20194 Amperes at t=1 microsecond. The magnetic field B is calculated using B = μ_{0}NI/d, yielding a value of 1.76229E-4 Tesla. The discussion highlights the importance of considering the rate of change of the magnetic field for accurate calculations.
  • Understanding of electromagnetic induction principles
  • Familiarity with solenoid characteristics and formulas
  • Knowledge of circuit analysis involving resistors and inductance
  • Proficiency in calculus for evaluating integrals and derivatives
  • Study the concept of inductance in solenoids and its calculation using L = μ_{0}N^{2}\piR^{2}/d
  • Learn about the relationship between magnetic flux and induced EMF, specifically dΦ/dt
  • Explore the effects of varying current on magnetic fields in circuits
  • Investigate the application of Faraday's Law of Induction in practical scenarios
Students and professionals in physics and electrical engineering, particularly those focusing on electromagnetic theory and circuit analysis.
geostudent
A cylindrical solenoid 30 cm long with a radius of 8 mm has 400 tightly-wound turns of wire uniformly distributed along its length (see the figure). Around the middle of the solenoid is a two-turn rectangular loop 3 cm by 2 cm made of resistive wire having a resistance of 190 ohms. One microsecond after connecting the loose wire to the battery to form a series circuit with the battery and a 20 resistor, what is the magnitude of the current in the rectangular loop and its direction (clockwise or counter-clockwise in the diagram)? (The battery has an emf of 9 V.)
B = μ[itex]_{0}[/itex]NI /d
L= μ[itex]_{0}[/itex]N[itex]^{2}[/itex][itex]\pi[/itex]R[itex]^{2}[/itex]/d
I = emf/R * [1-e[itex]^{-(R/L)t}[/itex]]
emf(induced)= d[itex]\Phi[/itex]/dt
I just want to check my reasoning here and get advice on how to approach a problem like this.
1. Since the Current is varying with time, I used I = emf/R * [1-e[itex]^{-(R/L)t}[/itex]] to find I at t=1microsecond and got I= .20194 Amperes
2. Used B = μ[itex]_{0}[/itex]NI /d to find B=1.76229E-4 Tesla
3. Induced Emf = -d[itex]\Phi[/itex]/dt where [itex]\Phi[/itex] = ∫B*dA
I took dA to be the cross-sectional Area of the rectangle
Then induced (EMF*Number of turns in rectangle)/R =I
I keep getting relatively close answers but not correct. I don't think I'm thinking of this n the right way. Where am I at fault?
The general approach looks alright, although I'm not sure what you're doing with the value of the current in the coil or the value of the B field for that particular time. It'll be the rate of change of the B field that you'll need, no?
Even so, the value you're getting for the current looks a bit odd. What values did you calculate for the inductance and the time constant?
