Magnetic Field Energy: Is It Greater to Push than Pull?
The discussion revolves around the energy dynamics between magnets, specifically whether the energy produced when one magnet pushes another away is greater than the energy required to move the second magnet into the first magnet's magnetic field. The conversation explores concepts related to magnetic fields, energy transfer, and the feasibility of perpetual motion using magnets.
  • One participant questions if the energy produced by a magnet pushing another away is greater than the energy needed to push the second magnet into the first magnet's magnetic field.
  • Another participant asserts that there is no free energy, implying that the energy dynamics do not support the initial hypothesis.
  • A participant expresses curiosity about the possibility of using magnetic field energy to create continuous motion, suggesting a sequence of magnets pushing each other into their respective fields.
  • Another participant counters the idea of perpetual motion, stating that motion would eventually slow down and stop, and emphasizes that perpetual motion machines have been debunked as impossible.
  • Links to external resources are provided to explain why perpetual motion and free energy concepts are not viable.
Participants generally disagree on the feasibility of using magnetic fields for perpetual motion, with some asserting that it is impossible while others explore the concept further.
The discussion touches on fundamental principles of energy conservation and the limitations of magnetic interactions, but does not resolve the underlying assumptions about energy transfer and motion dynamics.
iedoc
The idea is really simple, but it might not come out in words the same.
Is the energy produced from a magnet pushing another magnet away GREATER than the energy needed for a magnet to enter a magnetic field from the side?
I'll try to be more specific. You have two magnets, one in your left hand and one in your right hand, who's north poles (or south) are facing each other, so they will be pushed away when they get too close. If you put keep their orientation (left magnets north is facing right, and right magnets north is facing left) and put the left magnet above the right magnet, then "slide" or push the right magnet up into the left magnets magnetic field so that it gets pushed to the right, will the energy of the magnet being pushed to the right as it enters the left magnets magnetic field be GREATER than the energy it took to push the right magnet into the left magnets magnetic field?
No. There is no free energy.
i know energy cannot be created or destroyed. I think I might have asked the question wrong. basically what I'm wondering is if we are able to use the energy from the magnetic field. for example, if we are able to have a magnet pushed away from another magnet, into another magnets magnetic field, then have that magnet push the magnet away into another magnet's magnetic field, and continue doing that, so that the energy from the magnetic fields keeps the magnet in motion. does that make sense? I have it all perfectly laid out in my head, i just can't find a very clear description of what I'm thinking.
it's really a such a simple idea i doubt it would work, because I'm sure if it did, it would have been discovered a long time ago. but I'm still curious since I've never heard of it before
No, the motion would slow down and stop. Perpetual Motion Machines (PMMs) of all sorts have been explored and debunked as impossible.
We do not discuss PMMs or Free Energy schemes at the PF. Here are two good links for understanding why PMMs and Free Energy cannot work:
http://wiki.4hv.org/index.php/Free_Energy_Debunking
http://en.wikipedia.org/wiki/Perpetual_motion
  • · Replies 16 ·
13K
10K
