Approximation of string extension length
The discussion focuses on the approximation of string extension length when a string of length 'a' is stretched to a height 'y'. The length extension ΔL is derived as ΔL = √(a² + (y²/a²)) - a, which simplifies to a(√(1 + (y/a)²) - 1). For small displacements 'y', this can be approximated to y²/(2a) using Taylor's series. The participants confirm the validity of the approximation and clarify the application of Taylor's series in this context.
  • Understanding of basic geometry and trigonometry
  • Familiarity with Taylor's series and its applications
  • Knowledge of limits and approximations in calculus
  • Basic algebra for manipulating equations
  • Study Taylor's series in-depth, focusing on its derivation and applications
  • Explore geometric interpretations of string tension and displacement
  • Learn about small angle approximations in physics
  • Investigate other mathematical approximations used in physics
Students and educators in physics and mathematics, particularly those studying mechanics and calculus, will benefit from this discussion.
gboff21
A string of length a is stretched to a height of y when it is attached to the origin so making a triangle with length L=[itex]\sqrt{a^{2}+\frac{y^{2}}{a^{2}}}[/itex] and therefore a length extension ΔL= [itex]\sqrt{a^{2}+\frac{y^{2}}{a^{2}}}-a[/itex] which simplifies to [itex]{a(\sqrt{1+\frac{y}{a}^{2}}-1}[\itex]. <br /> <br /> Apparently when the displacement y is small, it can be approximated to y^2/2a<br /> <br /> How does that even work??[/itex]
Are you sure you got the result right? Seems to me like there should be a³, not a. This works by a method called Taylor's series. You can read about it in wikipedia: http://en.wikipedia.org/wiki/Taylor_series
Ah of course. I'm familiar with Taylor but I just didn't apply it. However, I've just done it and it is over 2a. Thanks for pointing me down the right track! :)
