Air pressure and velocity in a pipe
The discussion focuses on calculating air velocity and pressure in a 5-meter hose connected to a Crary centrifugal fan with a static pressure of 4 kPa and a volumetric flow rate of 40 m³/min. Key parameters include a hose diameter of 110 mm, a roughness of 0.05 mm, and a minor loss coefficient of 0.1. The calculations involve using the Darcy-Weisbach equation to determine the friction factor and Reynolds number, while also considering compressibility effects for gas flow. The user seeks to understand the back pressure experienced 1 meter from the fan outlet.
  • Understanding of fluid dynamics principles
  • Familiarity with the Darcy-Weisbach equation
  • Knowledge of Reynolds number and its significance
  • Basic concepts of compressible flow in gases
  • Research the Darcy-Weisbach equation for calculating pressure loss
  • Learn how to calculate Reynolds number for airflow in pipes
  • Explore compressibility effects in gas flow calculations
  • Study minor loss coefficients and their impact on flow systems
Engineers, HVAC professionals, and anyone involved in fluid mechanics or pneumatic systems who needs to calculate air flow characteristics in piping systems.
confused slug
This is NOT homework. The fan is a Crary Fan and the hose is Oregon PU used to distribute particles. I have tried a number of 'online' calculation sites but they return either conflicting results or 'infinite' values!
Dear All
I am trying to determine / estimate the expected air velocity and pressure at the end of a 5m long hose, supplied by a centrifugal fan coupled directly onto the hose. The information / assumptions i have are;
Fan System
Static Pressure: 4kPa
Volumetric Flow: 40m3/min
Pipe
Length: 5m
Diameter: 110mm
Roughness: 0.05mm
Minor Loss Coef: 0.1
Air
Temp: 15°c
Density: 1.1 kg/m3
Kinematic Viscosity: 10 E-6 m2/s
From this is it possible to estimate the velocity of the air stream at the start of the hose and at the and (v1 & v2) and the associated pressures (p1 & p2)? If it is ,what are the calculations?
I assume that due to the resistance caused by the pipe there will exist a 'back pressure' in the pipe. What would this pressure be 1m from the fan outlet (1m down the pipe).
Thanks
Confused
This flow can be quantified using the Darcy-Weisbach friction factor vs Reynold number correlation. It may be necessary to take into account compressibility if the fluid is a gas, in which case one would be solving for the pressure squared rather than the pressure to the first power.
  • · Replies 19 ·
  • · Replies 20 ·
12K
  • · Replies 45 ·
