Capacitor for high current discharge
The discussion revolves around the use of capacitors in conjunction with solar panels to charge batteries, particularly focusing on the challenges of low current output from solar panels and the implications of using rectifiers and regulators in the charging circuit. Participants explore the feasibility of storing energy in capacitors for high current discharge and the behavior of lithium-ion batteries in this context.
  • One participant suggests using a capacitor to store low currents from a solar panel to discharge high current to a battery, questioning if this is equivalent to direct connection without capacitors.
  • Concerns are raised about the minimum current that a lithium-ion battery would accept, with a participant proposing that any small current can charge the battery, affecting the charging time.
  • Another participant emphasizes the importance of using a rectifier to maintain steady voltage, noting that insufficient voltage could prevent charging.
  • There is a discussion about the use of a regulator and the potential confusion regarding the terminology of rectifiers versus regulators.
  • One participant describes their setup of connecting multiple solar panels and using a capacitor to stabilize voltage, questioning the effectiveness of this approach during cloudy conditions.
  • Concerns are expressed about the discharge behavior of the phone battery, leading to inquiries about the placement of a diode and the safety of using lithium-ion batteries for charging.
  • Another participant suggests that a switching regulator could be efficient for charging lower voltage batteries and could optimize charging speed.
Participants express differing views on the safety and suitability of using lithium-ion batteries versus NiMH cells, with no consensus on the best approach for charging configurations or the effectiveness of specific components like zener diodes and regulators.
Participants mention various assumptions about the behavior of solar panels, capacitors, and battery charging, but these assumptions are not universally agreed upon. There are unresolved questions regarding the stability of the regulator and the implications of cloudy weather on charging efficiency.
This discussion may be useful for individuals interested in solar energy systems, battery charging technologies, and the practical challenges of integrating capacitors and regulators in such setups.
ramonegumpert
Dear Experts
i have a solar panel but the current is not high enough .
I have about 5 volts to charge giving about max 100mA (specs).
I am thinking of using a Capacitor to store all the low currents such that when the capacitor is fully charged, I need a circuit to discharge all the high current in the capacitor to the battery.
I am not sure if this is the same as hooking up the panel to the battery without capacitors.
I also not sure is there a minimum current (at 5 volts) the lithium ion battery would accept current? Am I right to say any small amount of current will charge the battery at the right voltage and the only difference is how long it takes to charge?
By the way, I will add a rectifier to maintain a steady voltage.
But does this not mean that if voltage is not sufficient, there is no charging at all vis-a-vis without a recitifier ?
Eg. If I use a 7 volt rated solar panel, connecting to a rectifier taking about 2 volts, the remaining 5 volts will charge the battery. But if the sun is not strong enough, producing only 6 volts or less, the rectifier may not have 5 volts output . What happens? No charging?
Thank you for reading my question.
Have a nice day.
Best regards
Pascal
It usually is no different.
Li-I batteries are very fastidious and fussy, and are not safe to experiment with. They are easily damaged and can catch fire if conditions are not to their liking. https://www.physicsforums.com/images/icons/icon9.gif Can you use NiMH cells instead?
By the way, I will add a [strike]rectifier[/color][/strike] regulator[/color] to maintain a steady voltage.
If the voltage is lower than the regulator needs, then there will be no charging.
A 7v panel delivering 100mA should be about right for 5 x NiMH cells, each 1.2v. Place a current meter in series to verify that charging is proceeding okay. No regulator required. :smile:
Uh ... I thought solar cells produced DC voltage, no? You have one that produces AC voltage?
Dear NascentOxygen and Phinds
Sorry, my bad, I incorrectly used the word 'rectifier' for regulator.
NascentOxygen has given me great advice. I really appreciate your kind help.
By the way, I could not find a 7V solar panel at 100mA. The store only has 6V at 100mA.
So, I bought another 4 x 5v panels rated at 100mA and connected them as 10v pairs.
Because of the potential difference, I drop the voltage down using a regulator at 5.5v and connected a 1 farad capacitor at 5.5v before regulator whose output goes to charge the battery.
Based on the voltmeter, it seems that adding a cap stabilized the voltages a bit especially when the sky is cloudy. Is this observation making sense?
If I add a same cap after the regulator, would that make it even more stable? But what happens when the sky is too cloudy? would that not make the capacitor discharge to the solar panel? So, I added a small zener diode to block the discharge.
Still my phone, which has a larger lithium battery than iphone, is DIScharging rather than charging my phone.
That is why I wondered is it due to the position I placed the diode ? I could not understand why the phone is not being charged. For example, after 5 minutes, the charged % actually dropped rather than increased.
Best regards
Pascal
I didn't suggest you would. It was you who nominated that figure of 7V. :smile:
The store only has 6V at 100mA. So, I bought another 4 x 5v panels rated at 100mA and connected them as 10v pairs. Because of the potential difference, I drop the voltage down using a regulator at 5.5v and connected a 1 farad capacitor at 5.5v before regulator whose output goes to charge the battery.
One farad?!
It should make no difference, unless the regulator is not stable and is oscillating or something. Maybe you are using a switching regulator? What is the type number on the IC?
Data sheets for some regulators may specify where you can add a small capacitor to give it greater stability.
Capacitors draw practically no steady current, so you are not losing any power in the capacitor. Your inclusion of a zener diode is wrong. Zeners conduct in both directions, it can not help you. Leave it out. Possibly your battery may discharge into the regulator when the panels are producing no voltage; can you put a current meter in series there to measure any current in the wrong direction?
You are using the solar panel to charge a lithium cell? As I indicated, lithium cells are dangerous and are not sold for experimenters. I recommend that you charge only NiMH cells from your homebrew solar charger. You could charge 6 or 7 NiMH cells from your 10V panels and as NiMH cells are tolerant and relatively safe, there would be no need for a wasteful regulator. There may be a safer way to charge Li cells from the fully-charged NiMH cells.
A switching regulator could be very efficient and you could charge a lower voltage battery than your solar cell without losing appreciable energy. The regulator could be made 'intelligent' so that it charged your battery as fast as possible, too.
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 49 ·
  • · Replies 19 ·
