Is Ek0-Ek1 Greater Than Zero?
  • Context: Graduate
  • Thread starter Thread starter May11
The discussion revolves around the inequality Ek0 - Ek1 > 0, where Ek0 represents the initial kinetic energy and Ek1 represents the final kinetic energy of an object involved in a plastic collision. Participants explore the conditions under which this inequality holds, focusing on the mechanics of the collision and the relevant equations.
  • One participant requests help to prove that Ek0 - Ek1 > 0.
  • Another participant suggests proving the opposite, Ek1 - Ek0 < 0, and emphasizes the need for clarification on notation.
  • Several participants clarify that Ek0 is the initial kinetic energy and Ek1 is the final kinetic energy, with one stating that the energy loss should be a positive value.
  • There is a discussion about the system's specifics, with a participant noting that the type of object and the forces acting on it are crucial to understanding the energy changes.
  • One participant describes the collision as plastic, detailing the equations for the final velocity and kinetic energies, and reiterates the goal of proving Ek0 - Ek1 > 0.
  • Another participant provides a mathematical expression for the difference in kinetic energies and questions whether it is positive, leading to further exploration of the conditions under which this holds.
  • One participant asserts that the expression for Ek0 - Ek1 is positive based on the derived inequalities, while also mentioning that additional formulas may be needed for a complete proof.
  • Another participant comments on the mindset regarding problem-solving in physics, suggesting that there is no singular 'right' way to approach these problems as long as the logic is sound.
Participants express differing views on the validity of the initial claim and the necessity of additional formulas. There is no consensus on whether Ek0 - Ek1 > 0 is universally true, as the discussion highlights the importance of specific conditions and assumptions in the analysis.
The discussion reveals limitations in the initial problem statement, including missing assumptions about the system and the forces involved, which affect the ability to definitively prove the inequality.
May11
Hi there,
I need your help to prove the following, please:
Ek0-Ek1>0
Thanks in advance. (:
Try to prove that Ek1-Ek0<0
Seriously, if you don't explain your notation, then we can't help obviously.
Ek0 is the initial kinetic energy that an object possesses.
Ek1 is the eventual kinetic energy that an object possesses.
Try to prove that Ek0-Ek1 (energy loss) equals a positive value.
Did you get my question? need a further explanation?
Sure does. This is simply not true in general. You need to tell about the system, and what it is doing. With the information given we can do nothing.
Depending on the circumstances, an object's kinetic energy can either increase, decrease or remain constant. What are the circumstances in your case? What kind of object are we talking about? What forces act on it?
It is a plastic collision, masses exert forces on each other, ending up with a joint velocity (U). We fisrt have to express the equation of the velocity at the end of the collision, that is : U= Mv/M+m
Then, express the equation of Ek0 and Ek1 :
Ek0= Mv²/2
Ek1= (m+M)u²/2 = M²v²/2(m+M)
Then, prove that Ek0-Ek1>0 ...that is pretty much all! we are not given any further...
Two masses, actually.
V1 (velocity of M before the collision) = v
V2 ( velocity of m before the collision) = 0
Ek0= Mv²/2
Just write it out? It seems like you haven't even tried this.
[tex]E_0-E_1 = \frac{1}{2}Mv^2 - \frac{1}{2}\frac{M^2v^2}{m+M} = \frac{1}{2}Mv^2 \left( 1- \frac{M}{m+M} \right)[/tex]
Now what can you say about whether or not this is positive?
Mv²/2 is undoubtedly positive.
1-M/m+M:
1>M/m+M
M+m>M<1 = positive.
Umm, makes sense. The teacher said we have to use more formulas which are not given in the question, haven't expressed them, to branch out a little from what we are given. I will ask if your proof is valid and acceptable.
Thanks a heap! :)
Thanks a heap! :)
Haha, that's an interesting stance to take. If you plan on continuing with physics, I suggest you try to get out of this mentality that there is a 'right' way of arriving at a solution. If a given derivation or proof seems logically sound to you, then it's good. I have some physics major friends who are in a similar mindset, and when doing problem sets with me they always say things like, 'can you do that?', as if there were some mystical physics police that sets the rules for how you approach physics problems! Of course there's not, and as long as you don't abuse math, everything's fine!
With re: to this problem, all the physics is essentially in solving for the final velocity (where you have to apply conservation of momentum).
I will bear that in mind !
  • · Replies 75 ·
  • · Replies 39 ·
  • · Replies 29 ·
  • · Replies 38 ·
